Author Topic: How far back for H-pipe?  (Read 5091 times)
Offline GoodysGotaCuda
Re: How far back for H-pipe?
« Reply #15 on: May 12, 2008 - 07:04:20 PM »
Every engine will have different exhaust temperatures due to it's build and so the ideal location for the balance pipe will vary.
The correct place for the H crossover can be determined (oldschool backyard method ;))by marking a crayon line along the pipe,start the engine and get up to temp and the point where the crayon melts to is the ideal location for the crossover pipe.
Of course by necessity things like trannys in the way can over ride the best location. ???
I thought that old school method was for header extensions only, not for full exhaust? I also thought it was to be checked after a hard run or 1/4 mile pass. Given that i would think the crayon would melt within a foot or so of the header collector, hardly any room in most cars to stick it there.  :wave:
1976 Dodge Warlock
Wheel & Tire Specs:Link
« Reply #16 on: May 13, 2008 - 12:37:46 AM »
 I know that is used for header extensions , never for an H pipe
Offline IMNCARN82
  • LeDZeP
« Reply #17 on: May 18, 2008 - 05:26:23 PM »
I'd try and put it back far enough to get the tranny out without dropping the exhaust. Mine was too close for comfort.And then I had to alter it for the 5 speed. 1 " can make it or break it. :dunno:
71' Demon
75' Duster
87' Conquest TSI
56' Plaza
Boulder CO
Robert    "cuda bob"
Offline mikerallye
« Reply #18 on: June 10, 2008 - 04:02:43 PM »
What does the "H" pipe do?  :clueless: :clueless:
Offline Changin Gears
« Reply #19 on: June 10, 2008 - 04:51:40 PM »
An H-pipe (or X-pipe) allows each exhaust pulse to travel through both mufflers thereby reduceing back pressure.  This is why you can run say 3" pipes up to the H then reduce down to 2.5" after without adding restriction.  Its alot easier to run 2.5" tailpipes than 3".
« Reply #20 on: June 10, 2008 - 05:14:09 PM »
The "H" pipe makes it sound cool too.   :grinyes:
Offline 422STROKER
  • Member Since 6/3/06
« Reply #21 on: June 10, 2008 - 05:55:31 PM »
I ended up having a muffler shop weld up the whole thging and cut an H-pipe in as well.  Sounds nasty now with the 40 series muffs.  Resonance isn't tooo bad.LOL  Just have to find the sweet spot while cruising.
Tom
They cut the H-pipe far enough back to drop the trans through it. :2cents:
Tom
Offline johannes
« Reply #22 on: September 18, 2012 - 09:01:10 PM »
As long as the pressure can crossover bfore the muffler you will be fine
Fellas.
I just spent some extra time TRYING to capture the difference before and after H-pipe installation.
Yes I admit my camara skills leaves a lot to be desired, and my audio equipment even more so...
But it is the weather that sadens me the most
Did I jet my point across..... A "smoother tone to the ear" after H-pipe ?
Should I cut some of the footage out ?
Ohh well,...here goes, for your ears only... feedback welcome.
This video will be removed, and perhaps replaced by a better one?
Offline 422STROKER
« Reply #23 on: September 22, 2012 - 01:51:11 AM »
Nice video johannes.  Car is quieter on the road than I'd expect.
Tom
Tom
