Author Topic: FUEL SENDING UNIT FOR 70 CHALLENGER DO U HAVE TO DROP TANK  (Read 5818 times)
Offline geneo4116
  • 70 rt 383 auto blk/blk apprx 450hp
« on: April 29, 2008 - 05:10:24 PM »
TO INSTALL NEW UNIT DO YOU HAVE TO DROP TANK, AND HOW HARD IS IT TO DO .
Offline 73Chally
Re: FUEL SENDING UNIT FOR 70 CHALLENGER DO U HAVE TO DROP TANK
« Reply #1 on: April 29, 2008 - 05:29:34 PM »
Funny you ask that because I just did mine (watched more than helped) at the shop this morning.  The tank does not have to come out, but make sure you are down around a quarter tank full.  It looked very easy.  He just used a screw drive and hammer to spin the retaining disk about half a turn until it popped off, pulled the old unit out and popped the new one in, then reversed the process with the retaining disk.  It took all of about 5 minutes.  Now the disclaimer - This was done on a lift at shoulder height, but I would not think it would be much more difficult if you jack up the rear end and do it on your knees.
Offline Katfish
  • 70 Challenger
« Reply #2 on: April 29, 2008 - 05:38:16 PM »
Did mine without dropping the tank.
Offline 422STROKER
  • Member Since 6/3/06
« Reply #3 on: April 29, 2008 - 05:50:03 PM »
Tip the car up higher on the driver's side to minimize leakage.
Tom
Use a jack stand>LOL
Tom
Offline geneo4116
« Reply #4 on: April 29, 2008 - 06:05:22 PM »
WHERE IS IT AT EXACTLY
Offline 422STROKER
« Reply #5 on: April 29, 2008 - 06:27:37 PM »
It is on the drivers side of the tank, right on the side of it.
Tom :2thumbs:
Tom
Offline GoodysGotaCuda
« Reply #6 on: April 29, 2008 - 06:55:35 PM »
EASY ON THE CAPS.
-Thanks :D
1976 Dodge Warlock
Wheel & Tire Specs:Link
« Reply #7 on: April 29, 2008 - 06:58:17 PM »
Jack up the driver's side rear. Remove driver's side rear tire. I've had mine out a few times.  :bricks1: Taking out is easy. Putting back in is a little more difficult.
Offline NoMope Greg
« Reply #8 on: April 29, 2008 - 07:08:40 PM »
 :iagree: Putting it back is better done as a two-man job, especially is there's still fuel in the tank.
Greg
2003 Ford Escape XLS
Currently Mopar-less :(
« Reply #9 on: April 29, 2008 - 07:13:20 PM »
Hammer , screwdriver,  gas tank,  oh be careful. 1 spark can make a day go bad in a hurry
« Reply #10 on: April 29, 2008 - 07:30:04 PM »
Sounds like a brass punch would be safer...yet i've used a screwdriver a dozen times lol
1976 Dodge Warlock
Offline 73Chally
« Reply #11 on: April 29, 2008 - 07:32:42 PM »
Good point.  It might have been something else that he used.  He was real cautious with the whole thing (we replaced the fuel lines at the same time).
Offline cudadave72
  • you motorboatin sob!!!
« Reply #12 on: April 29, 2008 - 07:54:46 PM »
Ouch!!! :banghead: :bricks1:
1972 BS23 H code Cuda, B5 blue, 340 streched to 416 cu in, 727 w/ 8 3/4 rear, 7.23 in the 1/8 mile and 11.38@117mph in the 1/4 on drag radials   Under restoration! Coming soon... 440cuin R3 Indy SMALL BLOCK monster!!!!
Offline Challenger6pak
« Reply #13 on: April 29, 2008 - 10:29:37 PM »
I always use a brass hammer and punch for this.  I knew a guy who didn't.  When it went off it put him through his garage door.  It was the last thing he ever did.  IMO it is a freak accident to happen, but why take the chance.  The more empty the fuel tank is the more likely for a spark to cause problems.  Fumes explode.  Since it is best to do the sending unit on an empty tank, it makes it a dangerous task if done improperly.
Offline 72bluNblu
« Reply #14 on: April 30, 2008 - 02:28:42 AM »
Well this thread had good timing! Put my new sending unit in this afternoon! :2thumbs:
Just jacked up the driver's side rear and put it in, didn't even pull the wheel although it probably would be easier if you did. Non-sparking tools is definitely a good idea, although I would think that you're only using the screwdriver to loosen the retaining ring, so everything should still be sealed up at that point. Still much better safe than sorry. I just used a set of lock jaw pliers instead...
