Author Topic: Help tach just stopped working  (Read 1130 times)
Offline Justins72
« on: April 29, 2008 - 07:39:49 PM »
My tachometer all of a sudden stopped working. I checked the for fuses and nothing went out. The negative side of the coil is still tight with nothing looking broke. I have the stock ralley tach, so any suggestions? The coil has a black/yellow and a blue wire on the - side, which one is for the tach? thanks
Re: Help tach just stopped working
« Reply #1 on: April 30, 2008 - 12:47:31 AM »
check the plug at the firewall , it has it`s own grommet & goes trough seperatly
Offline Justins72
« Reply #2 on: April 30, 2008 - 07:25:32 PM »
checked the wire at the firewall everything seems to be plugged in. Any other suggestions? Could the tach itself just stopped working on me? I will pull the gauge cluster tomorrow to if i can find the problem.
« Reply #3 on: April 30, 2008 - 07:29:24 PM »
I think the back up light fuse is the tach fuse too. Did you use a test light on both sides in the fuse box?
« Reply #4 on: April 30, 2008 - 07:41:35 PM »
After the clock, the tach is next to go to heaven.  :grinyes:  It might have died on you.
