Author Topic: MSD wiring question.  (Read 863 times)
Offline shatar4
  • 71 Challenger
« on: April 30, 2008 - 05:54:41 PM »
I am about to order my engine bay wiring from Evans wiring and noticed that they have 2 kinds of wiring. Electronic ignition and points. I have a 6A msd box and MSD distributor. Which wiring set would work better for this type of set up? Thanks
1971 Triple black 340 Challenger
Offline NoMope Greg
Re: MSD wiring question.
« Reply #1 on: April 30, 2008 - 06:05:17 PM »
Electronic.  Points type is only if you are returning the vehicle to stock condition.  Someone who has worked with Evans before will know better, but I suspect that the electronic ignition set assumes a Mopar electronic ignition.  You may wish to call them and let them know you're using an MSD setup and see if they can pre-wire the harness for MSD.
Greg
2003 Ford Escape XLS
Currently Mopar-less :(
Offline 422STROKER
  • Member Since 6/3/06
« Reply #2 on: April 30, 2008 - 07:12:19 PM »
Good call Greg, if he is using the MSD setup it won't really matter as the instructions allow either or to exist in the car regardless.  I would get the elec just in case you want to swap it later, IE side of the road.LOL  I have a Mallort/summit ignition and left all the factory stuff n there just in case.
Tom :2thumbs:
Tom
