Author Topic: Neil Why The 512 Kit and Not the 528 or 543 Kit From 440source.com?  (Read 7813 times)
Offline The Cuda Guy
  • Support Our Troops
  • Pearl Harbor, HI
    • C-C.com
Neil,
Hey bro got a quick question I know you advocate the 512 kit but what about the 528 or 543 kits?  Im assuming its the addition of external oil pick up, but they say that the 528 kit can be made to work with an internal?  What say you????     :feedback:
Don
Member Since January 14, 2002
nivvy
Re: Neil Why The 512 Kit and Not the 528 or 543 Kit From 440source.com?
« Reply #1 on: April 30, 2008 - 10:08:09 PM »
Longevity / Rod Ratio and also at 528/543 you need some really good flowing heads to make that many cubes work at its potiential...  :2cents:
Yes cubic inches makes power but it has to be supported.... Don I say the 512 is the ticket..... I would have did it if 4.250 stroke cranks were handy then.....
Or if you just wanna say I have a 543 then go for it....
not answering for Neil as Im sure he will chime in......  :2thumbs:
what type of heads do you plan on running.......
  • Pearl Harbor, HI
    • C-C.com
« Reply #2 on: April 30, 2008 - 10:17:21 PM »
I didnt factor the head flow I just assumed it was the external pick up that kept him from recommending those other kits.  440source website said that 512 kit doesnt need that much modification ect compared to the other kits.  It could just be pratacality?  Inquiring minds want to know?
Don
nivvy
« Reply #3 on: April 30, 2008 - 10:20:38 PM »
Don
Study up.... I did to don............ It took me 3 months to buy my cam....... and then when I bougth it I sent it back and went solid roller.... I swear i must have had $300 in return shipping fees over the build............  :money:
  • Pearl Harbor, HI
    • C-C.com
« Reply #4 on: April 30, 2008 - 10:31:04 PM »
solid roller   :22yikes:
Dang I didnt know the 499 was packing a bump stick like that!  Sweet.
Don
nivvy
« Reply #5 on: April 30, 2008 - 10:32:24 PM »
Don
it is .639 /.643 lift after the lash setting.............  :scared: Ill never use anything but a roller cam again...........   :2cents:
don... we both registerd on  1/14 ....... lol   that is my new 3 digit lotto number 114 .........  :money:
« Last Edit: April 30, 2008 - 10:36:42 PM by StRoKer »
  • Pearl Harbor, HI
    • C-C.com
« Reply #6 on: April 30, 2008 - 11:02:54 PM »
If you win I want half!!!   :jumping:
Don
« Reply #7 on: May 01, 2008 - 11:21:07 AM »
dpending what you want ot build any conbo will work but for longevity I like the 512 for the longer rods , it gives a decent 1.72 rod ratio , you get less piston side loading & more combustion durtaion , longer burn time more torque etc with longer rods/ rod ratio , for racing the larger displacement May help power but for street the 512 offers long life & more then adequate power , basically more CI is Nto nessisary a big advantage
 I just did a 512 with ported factory Iron heads , basically you cannot leave the line without the tires spinning no matter how gentile you are with the clutch , , it has yet to be dynoed but should be int he 650 ft lbs torque range with 575 hp  , we are also using a flat tappet solid cam with close to .600 lift , I can spec a cam with over .600 lift as a flat tappet solid using 1.6 rockers
  • Pearl Harbor, HI
    • C-C.com
« Reply #8 on: May 01, 2008 - 02:12:19 PM »
So pretty much what your saying the type of rebuild most of us guys here would be doing the 512 is the way to go due to the extra stress that the biger kits have on the rods and pistions ect.  Im tracking now.  Thanks for the input Neil your the man.
Don
« Reply #9 on: May 02, 2008 - 02:09:15 AM »
you are welcome Don  :2thumbs:
Offline Jacksboys
  • Here Since 08/28/06 GEORGIA
« Reply #10 on: May 02, 2008 - 02:40:46 AM »
Great information.  I was wondering this myself.   :2thumbs:
Offline Husker Cuda
« Reply #11 on: May 02, 2008 - 10:39:19 PM »
I'm having a 512 440 source kit put together right now.  I had to go with an external sump due to the #1 rod hitting the sump tube.  The builder said he wouldn't recommend the small internal tube with this engine anyway, thought the external line would be better anyway.  Waiting for the kit from Mancini before we can finish the engine and get her on the Dyno.  I will post the numbers for you as I am running the 440 source stealth heads also.
1974 'Cuda 512 stroker 650HP Indy heads, Hemi 4 speed, pistol grip - restored to new.
1970 GTX 440/727 Y4 Gold w/ black interior
1969 Camaro SS 396 4-speed X22
1970 Chevelle SS 396 - 375HP M22 4 speed
  • Pearl Harbor, HI
    • C-C.com
« Reply #12 on: May 02, 2008 - 10:51:18 PM »
Thank you Husker!  I will be very interested to see your results.
Cuda Guy
Offline bb71challenger
« Reply #13 on: May 02, 2008 - 11:38:54 PM »
For everyday driving I am actually considering a 496 or something a bit smaller. I have heard from several people that bigger is not always better in a street/strip engine. What say you CP?
*Brett*
« Reply #14 on: May 03, 2008 - 03:26:47 AM »
496 in the 440 block actually creates a lower rod ratio as they use the 6.76 rod instead of the 7.1" rod so I still prefer the 512 but the piston is shorter , every modification is a trade off, so you have to lose something to gain somewhere else . Virtually any stroker is a monster , even the 451 loses 7 lbs from the rotating mass with keeping the 1.81 rod ratio & should easily beat up a 440 build .... how much more do we really need or can use in a street car ??
Basicaly short rod ratios & shorter pistons will shorten the life of any engine but given most of these cars are toys & rarely see 5000 miles / year maybe rebuilding in 10 years at 50,000 miles or less is not so bad but if it can last 20-25 years why not assuming we will even be allowed to drive them but it could be the last rebuild needed
