The main reason the Hemi K frames are not as cleanly finished as the others (big block/small block) is because since the Hemi components were not mass produced like the others, they went down their own assembly line in a jig, and they were hand welded. The mass produced ones were welded by machines and much more precise. Pretty much every one out there is going to be this way, and you will not find a show quality (finish-wise) one out there, unless it is one someone cut up and put back together themselves to make it clean. I guess it all depends on whether the restoration is back to factory standards, or if you don't mind modifying to taste. Depending on your shipping charges to send it back, have you considered selling it yourself? Either way, I'm sure we all look forward to your progress.
