Author Topic: headers and exhaust any thoughts  (Read 4303 times)
Offline KNOT0623
  • 1970 A66 Challenger
« on: May 01, 2008 - 03:00:19 PM »
for the 70 340 .030 over.....looked at magnaflow exhaust 15851 ...but dont know if I should use the factory ex manifolds....any thoughts on good headers that fit...70 challenger
Any help is appreciated!!!
thanks!!!
Russ
Get in, Sit Down, Shut up and HOLD ON!!!!
1970 A66 340 Challenger 4-speed
1970 T/A Challenger 4-speed
2006 Ram 2500 Diesel
2008 BMW M3 Vert
Offline hemiken
Re: headers and exhaust any thoughts
« Reply #1 on: May 01, 2008 - 03:44:37 PM »
I really do not think their is much to worry about in reagards to fitment with the small block pipes.  The question you should be asking is what size header pipes should you be running with your cam and engine combos to get the right answer. :2thumbs:
Offline Slotts
« Reply #2 on: May 01, 2008 - 03:48:02 PM »
Russ,
I would look into TTI for headers and the exhaust with Flowmaster mufflers.
Slotts
Offline KNOT0623
« Reply #3 on: May 01, 2008 - 03:54:02 PM »
Hey Ken...look at the positng for the cam you responed to....ur thoughts with that cam set up?
2008 BMW M3 Vert
Offline hemiken
« Reply #4 on: May 01, 2008 - 03:55:34 PM »
I had a look and i would get CP to pick the cam and then pipes to suite. :2thumbs:
Offline KNOT0623
« Reply #5 on: May 01, 2008 - 04:06:06 PM »
cp?
2008 BMW M3 Vert
Offline 72hemi
  • MEMBER SINCE JANUARY 2006
« Reply #6 on: May 01, 2008 - 04:46:40 PM »
Definitely love the Magna Flow mufflers. I have Flowmasters on my car now and am going to be replacing them with Magna Flow.
1996 Dodge Viper GTS Coupe
Offline NoMope Greg
« Reply #7 on: May 01, 2008 - 05:11:58 PM »
cp?
Chryco Psycho AKA The Canadian Engine God.  :clapping:
Greg
2003 Ford Escape XLS
Currently Mopar-less :(
« Reply #8 on: May 01, 2008 - 07:22:04 PM »
TTi makes the best fitting headers all other I can find go under the steering & are smashed flat after a couple of weeks , not a fan of Flowmaster mufflers , Dynomax , Hooker aero are better IMO , I would be looking at 2.5" pipe
 with the right cam grind Manifold work great too
« Reply #9 on: May 01, 2008 - 07:22:19 PM »
 too bad there are not many Canadian engines I guess  :roflsmiley:
Offline GoodysGotaCuda
« Reply #10 on: May 01, 2008 - 07:28:18 PM »
For what it's worth i have some cheapo summit headers on my barracuda. Lowered the front end pretty decently, summit adjustable shocks on all four corners...the only time i've smacked my headers is going about 45 through an intersection i didnt know had a huge dip in the middle of it. Under normal driving, besides that, they were kept dent free.
I would run 3" to 2.5" smooth reducers to mandrel bent 2.5" aluminized pipe, an X-pipe cross-over, dynomax, hooker, spintech mufflers are all good. I have flowmasters on my car, i wouldnt recommend them. Exiting exhaust like a AAR Cuda or a T/A Challenger will help promote scavange of the exhaust at speed, otherwise just ran out the back of the car will do. I would add atleast one oxygen sensor bung to the exhaust if you plan to get serious on tuning/tweaking that 340.
« Last Edit: May 01, 2008 - 07:32:35 PM by GoodysGotaCuda »
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline KNOT0623
« Reply #11 on: May 01, 2008 - 08:05:41 PM »
CP
What do you recomend for a cam...from the other post?  340 .030 over, running 3.91 gears w a 3sp OD trans.
Want it to run strong ...thinking of oversizing the cam and using rhodes lifters to help w vaccum and bottom end...any thoughts
2008 BMW M3 Vert
« Reply #12 on: May 01, 2008 - 08:09:37 PM »
Automatic or Stick? If an auto what converter. Also, power brakes? .030" doesnt mean much..what heads and intake manifold? Guess i could post in the other thread :D
1976 Dodge Warlock
« Reply #13 on: May 01, 2008 - 08:29:31 PM »
get more info & I can help with a recommendation , as I posted in the other thread Engle does make a wicked cam
Offline 422STROKER
  • Member Since 6/3/06
« Reply #14 on: May 01, 2008 - 09:09:45 PM »
I got no complaints of the Doug's headers.  They do have a 1 5/8 tube though.  Nice for the $$.  Do not go under the steering.
Tom
By tdavist, shot with DSC-P72 at 2008-04-26
Tom
