Author Topic: Alternator Wires  (Read 1702 times)
Offline BadJoey
Alternator Wires
« on: May 01, 2008 - 09:17:10 PM »
I'm hooking up the alternator .There is 3 wires . The one held on with a nut is easy .The 2 that slide on is the problem . One has 2 wires and the other has 1 .Which one goes on the highest post ? Thanks . :jumping:
Offline 422STROKER
  • Member Since 6/3/06
Re: Alternator Wires
« Reply #1 on: May 01, 2008 - 09:20:17 PM »
Be careful something sounds wrong if one connector has 2 wires.  That could be the horn depending on what year you got.  There should be 2 connectors with 1 wire in each.  Unless someone added something in?
Or I am crazy.LOL
Tom :bigsmile:
Tom
Offline 6packCuda
« Reply #2 on: May 01, 2008 - 09:30:41 PM »
Mine has the connector with 2 blue wires going to the post closest to the one held on with the nut. The other is a single green wire to the other post.
Offline 422STROKER
« Reply #3 on: May 01, 2008 - 09:32:49 PM »
Told you I was crazy. :bigsmile:
Tom :smilielol:
Tom
Offline BadJoey
« Reply #4 on: May 01, 2008 - 09:43:25 PM »
Just pluged them in . You guys aren't only good you are fast too . Thanks a million . :cheers:
Offline challeng61
  • This is how it looked when I purchased my R/T 1978
« Reply #5 on: May 02, 2008 - 02:08:08 PM »
I have attached a wiring diagram. It shouldn't matter which goes on which. But make sure you have the correct 2 wires to begin with.  :jumping:
Paul
70 R/T 440 Magnum Plum Crazy and 73 Dodge Challenger 340 4 speed ralley... Garage sale find.
Offline BadJoey
« Reply #6 on: May 02, 2008 - 09:34:03 PM »
Thanks Challeng61 but you obviously do not know me . All I see is a bunch of squigily marks . I feel good where I am but really thanks . :stirpot:
Offline 71 CUDDA
  • Newbie
« Reply #7 on: May 02, 2008 - 11:14:05 PM »
I HAVE A 71 BARRACUDA AND THE ENGINE HARNESS FRIED, I TOOK OUT THE OLD HARNESS,BUT WHEN I WENT TO ORDER THE NEW ONE COULD NOT DECIDE BETWEEN THE REGULAR HARNESS OR THE ONE MODIFIED FOR ELECTRONIC IGNITION. I HAVE MSD IGNITION BUT SEEMS INDEPENDENT OF HARNESS, WHAT EXACTLY IS THE DIFFERENCE BETWEEN THE TWO HARNESSES
