Author Topic: Anyone Buying The 440 Source Heads For $899.00  (Read 1953 times)
Offline The Cuda Guy
  • Support Our Troops
  • Pearl Harbor, HI
    • C-C.com
« on: May 01, 2008 - 10:34:21 PM »
Just seems like a good deal?  They are like $700.00 less than the compareable INDY heads?  I guess these heads are still unproven?  I did see a write up in one of the Mopar mags about them, they thought it was a good deal.  What do you guys think?
Cuda Guy
Member Since January 14, 2002
Re: Anyone Buying The 440 Source Heads For $899.00
« Reply #1 on: May 02, 2008 - 02:07:03 AM »
I will have feedback on these shortly , I have taken a bunch of pix & ported them already just need time to post it all
 bottom line they are a decent head IMO , the portmatching on the intake side is near perfect out of the box , the porting in the intake side is approx the same size as I port Irons heads to , there is some extra meat arount the intake valve guide whuch can be trimmed but not enough to fully shape the way i do the iron heads , the exhaust port is small , I typically open the iron heads bigger than the stealth heads are but there is lots of room to open them up , the exhaust  has minimal floor height with zero excess around the guide to remove or shape , the is virtually no excess flashing or core shift & slight ridges just inside the ports that should be blended
 decent head for the $$ , not a lot of port clean up needed , I would like to see a raised exhaust floor , smaller volume heart shaped swirl chamber & 10 * locks & retaineers used
 I will try to get this set onto a flow bench soon to see what the flow is like
Offline Jacksboys
  • Here Since 08/28/06 GEORGIA
« Reply #2 on: May 02, 2008 - 02:16:04 AM »
Great info Chryco, I was wondering the same thing.   :2thumbs:
« Reply #3 on: May 02, 2008 - 02:17:12 AM »
I started at thread in the Proven section
nivvy
« Reply #4 on: May 02, 2008 - 04:46:19 AM »
Cuda Guy
If you get on moparts they have been bashing those heads for months.... all kinds of quality issues..... yes $899 but by the time your done you will be in much deeper.... its a total crap shoot with those heads......  :2cents:
However the guys that got them all fixed up and have ported them got good numbers.... One of the issue is the locks as neil recomends the *10 locks... all kinds of head gasket firering issues... etc... heads need machining to run 1.6 rockers an the list goes on........  :eek4:
 I say wait for the new batch 440 "race" head..... hopefully have all the quality issues gone...
« Last Edit: May 02, 2008 - 05:11:59 AM by StRoKer »
nivvy
« Reply #5 on: May 02, 2008 - 05:00:23 AM »
Food for the thought cuda guy.....  there is a 512 combo thre also :2thumbs: IMO  the crank packages seem to have good success.... heads  :22yikes:
I still say wait for the "race" head version... hopefully quality has gotten better.... too much of a gamble right now...
http://board.moparts.org/ubbthreads/showflat.php?Cat=0&Board=Racer&Number=4173160&Searchpage=2&Main=4133873&Words=440+%2Bsource+%2Bheads&topic=&Search=true#Post4173160
http://board.moparts.org/ubbthreads/showflat.php?Cat=0&Board=Racer&Number=4399032&Searchpage=1&Main=4399032&Words=stealth+%2Bheads&topic=&Search=true#Post4399032
http://board.moparts.org/ubbthreads/showflat.php?Cat=0&Board=Racer&Number=4264670&Searchpage=4&Main=4262829&Words=440+%2Bsource+%2Bheads&topic=&Search=true#Post4264670
http://board.moparts.org/ubbthreads/showflat.php?Cat=0&Board=Racer&Number=4237025&Searchpage=5&Main=4231605&Words=440+%2Bsource+%2Bheads&topic=&Search=true#Post4237025
http://board.moparts.org/ubbthreads/showflat.php?Cat=0&Board=Racer&Number=4227383&Searchpage=2&Main=4226110&Words=440+%2Bsource+%2Bheads&topic=&Search=true#Post4227383
http://board.moparts.org/ubbthreads/showflat.php?Cat=0&Board=Racer&Number=4133873&Searchpage=3&Main=4133873&Words=440+%2Bsource+%2Bheads&topic=&Search=true#Post4133873
http://board.moparts.org/ubbthreads/showflat.php?Cat=0&Board=QuestionAnswer&Number=4366528&Searchpage=1&Main=4366108&Words=440+%2Bsource+%2Bheads&topic=&Search=true#Post4366528
Call jeff at modern cylinder head... he has done them... he will tell you the full skinny on the heads and what you are lookin at cost wise....  :2cents:
http://www.moderncylinderhead.com/
If your still not done with the motor by the time I get my indy's I'll give you first dibs on my Fully ported eddys if your interested... They were $3000 to build but you get super special cant pass up pricing..........  :2thumbs:
« Last Edit: May 02, 2008 - 05:29:05 AM by StRoKer »
Offline oldkimmer
« Reply #6 on: May 11, 2008 - 02:40:06 AM »
 :canada:............cnc stealths r $1,999.99 max port cc=255....aluminum in stealths seems to soft, possibly y they r pushing out head gaskets....indy ez port =270cc unported, approx same $........kim.......
The beast has been unleashed........Thems the hazzards..........Unleash the beast......
