Author Topic: Will these heads work on my 383?  (Read 3480 times)
Offline arcticmopar
  • Yukon Canada
Re: Will these heads work on my 383?
« Reply #15 on: May 09, 2008 - 11:17:27 PM »
Thanks, bb71challenger!  :thumbsup:
But curious, why would a 383 be better than a 400?  Isn't a 400 a bored out 383, which is good?  :clueless:
I belive when comparing original pistons, all 400's had low comp.(8.0-8.5?) and most 383's had approx. 9.5? ??? Even though they were cast with a bigger bore, the 383's will usually respond better to HP mods. Now rebuild both with the same hi comp. piston and well,cubes are cubes! :naughty:
RUNS WHITH SISSORS!  and  DIGITALY CHALLENGED!
Offline bb71challenger
« Reply #16 on: May 10, 2008 - 01:12:00 AM »
yeah that is a big factor along with the fact that every 383 I have ever seen had a forged steel crank in it. But you are right, built to the same specs, cubes are cubes.
*Brett*
« Reply #17 on: May 10, 2008 - 02:56:38 AM »
400 block with a 440 steel crank & rods & some compression & look out
« Reply #18 on: May 10, 2008 - 07:27:37 AM »
 :iagree:  turns a 400 into a monster. Just giving it good compression and a cam will to.
Offline hemiken
« Reply #19 on: May 10, 2008 - 07:29:19 AM »
400 Block + 440 Crank = 451 ci
Offline Changin Gears
« Reply #20 on: May 10, 2008 - 07:53:55 AM »
The low deck 451 is pretty nice.  Headers fit better and its alot easier to change plugs.
Offline Super Blue 72
    • Phil's Super Blue '72
« Reply #21 on: May 10, 2008 - 01:36:45 PM »
Cool!  Thanks for the responses! :thumbsup:
Just collecting parts right now and playing around with the 383.  We'll see what happens in the future.
I'll keep my out for other fun stuff....a 400ci block eh?  :sly:  Hmmm....
