Author Topic: 71 CUDA ENGINE HARNESS  (Read 1654 times)
Offline 71 CUDDA
  • Newbie
« on: May 02, 2008 - 11:20:05 PM »
I HAVE A 71 BARRACUDA. I FRIED THE ENGINE HARNESS,WHEN I WENT TO ORDER THE NEW HARNESS , I COULD NOT DECIDE BETWEEN REGULAR HARNESS AND HARNESS MODIFIED FOR ELECTRONIC IGNITION I HAVE MSD IGNITION BUT SEEMS INDEPENDENT  OF HARNESS . WHAT EXACTLY DO THEY CHANGE TO MODIFY THE HARNESS FOR ELECTRONIC IGNITION
Re: 71 CUDA ENGINE HARNESS
« Reply #1 on: May 03, 2008 - 03:03:33 AM »
they would add the 2 wire plug to the dist & the 5 pin plug for the ECU , neither of which is needed to make the MSD work
Offline 71cudda
« Reply #2 on: May 03, 2008 - 11:04:22 AM »
thanks for the info,so if i order the regular harness, will it have the same alternator clips because i noticed on the modified harness it said "must use a 70 or later style alternator" but the regular harness did not                            '
« Reply #3 on: May 03, 2008 - 11:31:21 AM »
the std harness will work fine with the MSD, you will need to connect the power from both the blue 12 v wire & the brown start wire at the ballast to the red MSd switch wire
if you use the old style Alt & reg the wiring for the reg will be wrong
Offline 71cudda
« Reply #4 on: May 03, 2008 - 04:50:40 PM »
thanks again, im clear now
