Mike, if your panels are lined up right , just like stock factory, the hood has the under holes in it. You can put your plates and studs on, use your girlfriends lipstick :roflsmiley:and see if it is in the center. Then use a hole saw for metal. It has a guide drill bit in it for a starter. The hole will be rather big anyways . Look at the chrome top , you will see it is a bit bigger then your studs. Use that for your guide on size. Put tape on top of the hood where the hole comes through when drilling. It keeps the hole clean and from chipping, which you said you didnt care about right now...
