I started using AN stuff last year. I like it. Can you get a fuel line without a hose end on it? Mayby a AN to hard line fitting?Cut the flared ridge off. I have a black Jegs 3/8 fuel line to 6 AN fitting sitting here if you want it. I needed 7/16. Mayby get a pre-made fuel line... Check Jegs fuel inlet fittings section.Or the Fuel fittings,hoses,lines section for adapters.
