Author Topic: stupid question how do i tell if me sending unit is bad  (Read 2217 times)
Offline geneo4116
  • 70 rt 383 auto blk/blk apprx 450hp
« on: May 04, 2008 - 07:49:35 PM »
 :dunno:how do i tell if sending unit is bad ,or if its the fuel gauge
Re: stupid question how do i tell if me sending unit is bad
« Reply #1 on: May 04, 2008 - 07:57:21 PM »
Not a stupid question, go easy on yourself there. :2thumbs:
I'm no pro , but this is what I do
First, pull the single blue wire off the sending unit, ground the wire, and then turn the ignition key on the gauge should go to max full right away. If it does, then pull the sending unit, and useing an omh meter check to see if you have resistance and all the way through the scale
Offline geneo4116
« Reply #2 on: May 04, 2008 - 07:59:09 PM »
right on ill give er a try :bigsmile: :bigsmile:
« Reply #3 on: May 04, 2008 - 08:06:56 PM »
power flows to the guage & through it down to the sender so , if you have a pulsing power at the sender wire the rest of the circuit is ok , i fthere is no power of the guage doesn`t move check for power on both sides of the guage , if there  is power only on one side the guage is the prblem , , I assume the oil & temp guages are working OK ?if so there is power from the voltage reg at least
Offline geneo4116
« Reply #4 on: May 04, 2008 - 09:37:14 PM »
yes oil and temp are working should i ground the wire on the sending unit the one that pushes on the connector
« Reply #5 on: May 04, 2008 - 09:38:33 PM »
Yes you can do it that way or look for a pulse with a test light at the same place like neil said.
Offline geneo4116
« Reply #6 on: May 05, 2008 - 08:19:44 AM »
extreley helpful will get back to you in a few days, greatly appreciated
