Author Topic: new high pressure oil pump - no gasket between block & pump, right?  (Read 579 times)
Offline BB73Challenger
Hi guys -
The reason I ask is, I'm getting a huge oil leak on the bottom of the engine up front!
I wanted to up my oil pressure and opted for a new Meling high pressure pump.
It came with no gaskets, as well as the old pump appeared to not have any gasket material between them.
Now there was an o-ring on the shaft of the oil pump, the old one it was brittle and cracked as I tried to remove it.
I simply dug through my pile of extras and came up with an old gasket set that appeared to have the necessary o-ring, as it appeared no one in the local auto part stores could even get me one.
Now I believe this mess coming from the increased oil pressure, but something like a timing chain seal would not reflect the increased oil pressure, right.
That would be for the "closed" oiling system like bearings, right?
I was curious if I was missing something on this new oil pump since it wasn't a problem till I made the switch.
Any input is greatly appreciated as always, Thanks!!
Jeff from Cleveland, Ohio
Offline Changin Gears
Re: new high pressure oil pump - no gasket between block & pump, right?
« Reply #1 on: May 04, 2008 - 09:14:46 PM »
Big blocks have a gasket between the pump and the block.
« Reply #2 on: May 05, 2008 - 05:53:57 AM »
That would explain alot - thanks.
