Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Interior and Gauges
(Moderator:
Chryco Psycho
Cant remove key
« previous
next »
Print
Pages: [
1
Author
Topic: Cant remove key (Read 2633 times)
MDMoparDude
Jr. Member
Cant remove key
on:
May 04, 2008 - 10:31:34 PM »
I have a 70 Chally, the ignition key has become stuck. I cannot turn it back far enough to remove it from the ignition. It will turn to the start, and on position. Is there anything this could be besides needing a new ignition switch.
Logged
422STROKER
Sr. Resident
Member Since 6/3/06
Re: Cant remove key
Reply #1 on:
May 04, 2008 - 10:32:44 PM »
I think You need to rotate the lower column. I think this one has come up before.
Tom
Logged
Tom
GoodysGotaCuda
Sr. Resident
Re: Cant remove key
Reply #2 on:
May 04, 2008 - 10:33:27 PM »
4-speed? you got it in reverse?
Logged
Build Page:
Goody's 'Cuda Build Page
1976 Dodge Warlock
Wheel & Tire Specs:
Link
Alaskan_TA
Guest
Re: Cant remove key
Reply #3 on:
May 04, 2008 - 10:36:47 PM »
It is part of the 1970 only lockout feature. I think it is explained in the owners manual?
Logged
MDMoparDude
Jr. Member
Re: Cant remove key
Reply #4 on:
May 04, 2008 - 10:39:51 PM »
I have tried pushing, pulling, everything I can think of, will have to check it again next weekend. This could be an idiot error I admit..........
Logged
Chryco Psycho
Administrator
C-C.com Guru
Re: Cant remove key
Reply #5 on:
May 05, 2008 - 03:41:53 AM »
as above rotate the lower column , 70 only was not spring loaded to return & was driven by linkage from the trans , with the rod disconnected the column will rotate trapping the key
Logged
MDMoparDude
Jr. Member
Re: Cant remove key
Reply #6 on:
May 05, 2008 - 05:38:37 PM »
sorry, dont understand what you are trying to tell me chryco?
Logged
BadJoey
Full Member
Re: Cant remove key
Reply #7 on:
May 05, 2008 - 08:11:55 PM »
Chryco speaks the truth . I had the same problem and didn't try it for a few days (sounded too easy) . The key came right out
Logged
Chryco Psycho
Administrator
C-C.com Guru
Re: Cant remove key
Reply #8 on:
May 05, 2008 - 08:27:34 PM »
just before the column tapers down to go under the dash there is a larger diameter housing , grab it with both hands & rotate it [clockwise I think ] to the end of it`s rotation , you should now be able to remove the key
Logged
MDMoparDude
Jr. Member
Re: Cant remove key
Reply #9 on:
May 05, 2008 - 09:38:28 PM »
Gotcha Chryco, will try that this weekend.
Logged
MDMoparDude
Jr. Member
Re: Cant remove key
Reply #10 on:
May 11, 2008 - 11:35:17 AM »
That worked like a champ Chryco, thank you. Question now is, how do I keep that from happening again?
Logged
ksierens
Sr. Member
Re: Cant remove key
Reply #11 on:
May 11, 2008 - 03:05:51 PM »
Only sure fire way is to re-install the reverse lockout linkage. Mega Parts sells it I think.
Of course I never had it in mine either since it had headers when I bought it. You just get used to twisting the column when the key won't come out.
Last Edit: May 12, 2008 - 06:54:42 PM by ksierens
Logged
1970 Triple Black Challenger R/T 440 Six Pack - 4 Speed - 3.55 Dana
Kurt - SE Michigan
Chryco Psycho
Administrator
C-C.com Guru
Re: Cant remove key
Reply #12 on:
May 12, 2008 - 02:03:01 AM »
doesn`t really matter know that you can easily solve it
Logged
ShelbyDogg
Sr. Resident
Re: Cant remove key
Reply #13 on:
May 14, 2008 - 04:20:38 PM »
Quote from: MDMoparDude on May 11, 2008 - 11:35:17 AM
Get a small spring and hook it to the arm that sticks out of the column, in the engine compartment. hook it to something that will keep the arm pulled down.
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
Interior and Gauges
(Moderator:
Chryco Psycho
Cant remove key
