I bought some 2x3 .083 stock to put in some thru-the-floor subframe connectors. Cost me $30 for the pair. I was thinking that my convertible needs to be stiff and the XV connectors were too hard to put in. A friend stopped by and talked me into not cutting my new floors in case that I have to sell it one day. I listened……
Here are the 2 side by side. You can see why the 2x3 is stronger. If this was a race car, I would go 2x3.
I held one up to the floor to check for fit.
I had to peel down the torque box and slice a section and bend it down to fit around the front spring bracket. This piece was later bent up and around then welded to that bracket. The gap closes up as I match the floor.
If you have a contour gauge, it helps to get an accurate copy of the floor. Look how the bottom of the guage also takes the shape of the floor.
This helps transfer a pattern but not really needed.
Here it is marked for grinding. I just kept going side-to-side, marking where it hit, then grinding, then doing it all over again. I am on a creeper, no rotissery. Must have fitted this thing about 15 to 20 times
Here it is ready for welding.
I hate welding upside down! It would have looked better if I was sitting on a stool. Now I have to grind my crappy welds.
Nice and level with the rear frame, NOTHING hanging down! You can see where I welded the torque box to the bottom.
Took about 8 hours for the one side. Well worth the effort! No holes in my floor!
