ShelbyDogg's 71 Challenger Pace Car (clone)
Author Topic: ShelbyDogg's 71 Challenger Pace Car (clone)  (Read 100567 times)
Offline ShelbyDogg
Re: ShelbyDogg's Pace Car (wannabe)
« Reply #15 on: May 07, 2008 - 03:09:55 PM »
I have a set of 15x10s Rallyes with 295-50s, that I bought from HANEY (Jamie) in the for sale section. I'll probably use those for the Muscle look. Those wire hubcaps are a rare option that only came on 14" wheels. Right now, I have 2 flat hoods and a T/A hood, but would love another Rallye hood for it.
Offline thedodgeboys
  • ''Normal’s Overrated''
    • THE DODGE BOYS
« Reply #16 on: May 07, 2008 - 04:46:12 PM »
The gas tank makes it easy to take out and move far away when the sparks are flying.  I had a very bad experience with gasoline and fire around '82. After a dirty transmission job, I was trying to clean my garage floor with soap and water. I used a little gas and it cleaned great, so I used a lot of gas!  Fumes built up, gas water heater decided to fire up, Boom, air was on fire with me in it. I put out the basement garage fire but fumes had traveled up a wall and started the attic on fire. Had to call 911 to put that one out. (good thing I was renting)
:roflsmiley: I bet the owner thought the same thing :smilielol: NOT :faint: :2thumbs:
 :stirpot: i LOVE IT !   :smilielol:
The TA hood could look great in body color you could say your pacing the field faster than the rest.  :burnout:
Go Fast & Have Fun...
Offline ShelbyDogg
« Reply #17 on: May 09, 2008 - 12:03:30 AM »
I spent a couple of hours today cutting out the left floor. I'm leaving the hump and linkage for now, because I might try to mock up the 518 and figure out the slap-stick linkage problem that has never been answered, If I put in a 4-speed later and not use the 518, at least I'll have a "how-to 518 an e-body" for this site.
« Last Edit: August 23, 2008 - 06:18:57 PM by shelbydogg »
Offline 71340RT
« Reply #18 on: May 09, 2008 - 12:56:17 AM »
Rob looks like not much of the floor was good. I like the idea of a overdrive and FI and it should get pretty good gas mileage.
70 Plymouth Cuda 340 4-speed
2003 Dodge Stratus RT coupe
2014 Ram Express 5.7 Hemi 4X4
Offline Jacksboys
  • Here Since 08/28/06 GEORGIA
« Reply #19 on: May 09, 2008 - 03:03:16 AM »
I hope you can figure out the 518 linkage problem.  I would love to put one in my car.   Good luck  :2thumbs:
Offline Jacksboys
« Reply #20 on: May 09, 2008 - 12:52:40 PM »
The 518 seems simple enough. Once the trans case is modified, it seems that all I would have to do is weld a "U" shaped arm to go around the new fatter case. This arm would connect the top and bottom of the arm that runs down vertically through the tunnel, to the trans.
If you can make it work, you should copyright it and sell them.  You could make a bundle.   I would buy one  :2thumbs:
Offline ShelbyDogg
« Reply #21 on: May 10, 2008 - 02:21:30 AM »
If you can make it work,   I would buy one
Tonight, I took the whole passenger  floor and the windshield out. I had a roll of windshield wire from Harbor Freight. so it was easy pulling it out after using a grinder and cut-off wheel on the thick, hard-as-a-rock, urethane. The heat dug a trench and softened it up so pulling the wire was easy. I've used regular wire before but this braided windshield wire was worth the few dollars that I paid for it.
I included a picture of the slap-stik linkage for the 518 project.  The part that the others are having problems with is this vertical bar. When the new fatter 518 case is installed, It's width takes up this space where the bar is.   I don't see it as a problem.  I have a welder and I can make just about anything.
« Last Edit: August 23, 2008 - 06:23:39 PM by shelbydogg »
Offline Jacksboys
« Reply #22 on: May 10, 2008 - 02:34:18 AM »
Thanks for the pics.  I will be watching for your updates.  Good luck.   :2thumbs:
Offline CHUCKS71
  • "IF YOUR NOT FIRST YOUR LAST"
« Reply #23 on: May 10, 2008 - 07:47:49 AM »
 :2thumbs: I was going to mock up my 518 the same way with the floor out But I got lazy and went to a 833 4spd!I was thinking if the trans didn't fit through the cross member I was going to from and weld some 1/4 steel on the hump of the cross member so if I had to trim some of the under side it wouldn't lose any strength.
:burnout::22yikes::burnout:    www.ronpaul2008.com
71 Challenger 4spd   www.conservativepunk.com
03 Ram diesel 6spd    http://s105.photobucket.com/albums/m222/chucknutz/1971%20Challenger/
Offline ShelbyDogg
« Reply #24 on: May 23, 2008 - 01:02:55 AM »
I'm done with the 518 mock up and it works.  See the pics in the trans and drivetrain section under Carlwaski's 518 thread.   I pulled the dash and cleaned out the winshield sealer.  This thing must have leaked lots. the channel around the winshield was full of rock hard urethane. I took a buch of pics of the cowl rot holes. There may be more on the heater side.
« Last Edit: August 23, 2008 - 06:36:12 PM by shelbydogg »
Offline Super Blue 72
    • Phil's Super Blue '72
« Reply #25 on: May 23, 2008 - 12:48:52 PM »
 :22yikes:  Holely cowl!  :scared:
Nice progress, Rob!  :thumbsup:
Offline ShelbyDogg
« Reply #26 on: May 30, 2008 - 12:40:35 AM »
Pulled the dash and everything in the engine compartment except the engine.  I'm waiting for the weekend to get my trailer and friend's cherry picker to pull it. Today I took an old bed's frame apart and used the metal to make the door struts to keep my body stiff when I turn it over. Here are some pics. I'm welding the front mount to the windshield area and bolting it to the holes that the convertible top's frame bolts. It should be stronger than the bar others use to attach the top hinge to the door latch striker. Mine allows the door be put back on and close.
« Last Edit: September 18, 2008 - 12:47:12 PM by shelbydogg »
Offline hemiken
« Reply #27 on: May 30, 2008 - 12:45:20 AM »
Hey Shelby D................
That is a really good idea, i will have to steal that idea when time comes for my own build buddy.  Glad you shared that. :cheers: Thanks........ :2thumbs:
Offline ShelbyDogg
« Reply #28 on: May 30, 2008 - 11:54:33 AM »
I think my way would add more strength than uscartools brace, in the pic below.  Mine is an angle instead of just a strap and higher up. I can still crawl through the hole too. Anything is still better than nothing.  A friend of mine just did his Vert metalwork on a rotissery and didn't have one on at all.  He welded his frame connectors on when the car was upside down too.  He thinks that if it isn't right, then he will have to take it somewhere to have it "bent".
« Last Edit: August 23, 2008 - 06:37:27 PM by shelbydogg »
Offline hemiken
« Reply #29 on: May 30, 2008 - 09:44:15 PM »
No, i must say i like your idea a lot more than what they have pictured.  Only a slight advantage with what they have over nothing at all :faint:
