I still had to do my other seats.
Here is the Passenger seat. The foam was usable but for for $100, it got new buns. THIS IS THE DELUXE SEAT COVER
I unbolted the back, flipped it over and started cutting off the old hog rings.
Here is the old and new foam,
There is a piece of wire on the back of the old foam that pulls the insert into the foam to give it it's shape.This is the old usable old one I pulled out to reuse. You can see it behind the spring in the picture above. It is different shape if you don't have the deluxe seat cover!
I flipped it over and started hog ringing the insert wire to the rear foam wire through the foam. See my driver's seat pics above to see how I made the insert wire, then installed it. Here it is pulled in.
I hog ringed 2 layers of burlap over the seat springs. to protect the foam. My old seat didn't have it.
I put the cover and foam over the seat frame and hog ringed the foam stips to the frame. These strips get glued to the foam per the instructions that came with the foam buns. I then started wrestling with it on a piece of cardboard on the garage floor.
It is like trying to sit on an alligator and pull his belly skin up and over his face and body!
You just keep pulling here and there, massaging the cover, pulling some more, letting it absorb some heat from the sun, then pull and tug some more. You better have some good hand and grip strength. Check for straightness, then hog ring it down!
Did the bottom the same way. Made 2 wires. One for the cover insert, one for under the foam then hog ringed them together. I used 1/8" steel rod from Ace Hardware to bend up a new one and place it behind the middle foam area. it is a copy of the original, just not rusted and deteriorated yet. Then started the pulling and tugging on the floor.
This was the rear seat back for a convertible. No foam at all. Just a smelly nasty cotton stuffing like inside an old chair grandma sat in. It went right to the garbage. The frames were so rusty that I painted them with 2 coats of RUST MORT, then primer, then black Rustoleum.
Went to the Hobby Lobby store and bought waterproof polyester stuffing. 24" tall, 2" thick, $20 a yard.
Also found a piece of carpet pad to put under it.
Ready to install the cover. Seat frame has burlap, then padding, then polyester pad.
Used new burlap and OLD FOAM for the rear seat bottom. Very easy to put on new covers over old foam!
Rear seat installed.
Nice new white interior!
Do a little everyday and you'll be driving someday!
