Author Topic: ShelbyDogg's 71 Challenger Pace Car (clone)  (Read 100491 times)
Offline 71340RT
Re: ShelbyDogg's Pace Car (wannabe)
« Reply #45 on: June 20, 2008 - 02:27:10 AM »
Rob nice pictures and I'll have to come by sometime and check the Challenger out in person. Looks like you are moving right along on your Pace car.
Jeff
70 Plymouth Cuda 340 4-speed
2003 Dodge Stratus RT coupe
2014 Ram Express 5.7 Hemi 4X4
Offline Jacksboys
  • Here Since 08/28/06 GEORGIA
« Reply #46 on: June 24, 2008 - 02:53:17 AM »
Hey Rob,
I was thinking, since you want to get good mileage and still have a V8, have you considered using a 273?  I mean you could use flat-top pistons with the small chamber 318 heads so that your compression could be around 8.5-9:1.  Use the original 340 cam with 1.6 rockers and the 273 should have a decent amount of power.  This way you still have the rumble of a V8 exhaust, but should get even better mileage than a 318.  What do you think?
Offline CHUCKS71
  • "IF YOUR NOT FIRST YOUR LAST"
« Reply #47 on: June 24, 2008 - 05:19:32 PM »
Today I cut the old frame out and installed my straight replacement. It is a little bit rusty but it's all I have right now. Here are some pics of it cut out. I have it bolted in with k-frame bolts, clamped, and it's ready to be welded in. It's kind of hard to see the framerail missing with all of the junk in the picture.
We knew you could do it!  :2thumbs:
:burnout::22yikes::burnout:    www.ronpaul2008.com
71 Challenger 4spd   www.conservativepunk.com
03 Ram diesel 6spd    http://s105.photobucket.com/albums/m222/chucknutz/1971%20Challenger/
Offline Jacksboys
« Reply #48 on: June 25, 2008 - 03:18:13 AM »
The 318 in it is still good and numbers matching. I think I'll just do the rings and timing chain set, then paint it. The gas mileage will come from the throttle body fuel injection setup that I have ready to bolt on.  The smallest I would ever go is a 318.
Oh, I did not realize the engine was still in that good of shape.  Sounds like a plan to me.   :2thumbs:
Is the throttle body setup that you have made by Holley or something else?
Offline ShelbyDogg
« Reply #49 on: July 11, 2008 - 12:45:51 AM »
Got back to work on the car today. I was working on and Imperial for a guy to get money to pay for sheetmetal for my car. $1400.00 was his bill. woohoo!    It's all being picked up at Carlisle by a friend from Megapart's spot.  Front and rear floors, outer wheel houses, trunk extensions and cowl-corner repair sections.
While I'm waiting to metal,  I cut off the cowl and finished welding the frame rail in.  The spare cowl, framerails, and firewall was GIVEN to me, last year, by DRAGFISH, a member here and friend of Tony Miller. Thanks Dragfish!
« Last Edit: August 23, 2008 - 06:44:52 PM by shelbydogg »
Offline ShelbyDogg
« Reply #50 on: July 13, 2008 - 05:55:48 PM »
Today, I worked on the left side hinge area.  It ws poorly repaired years ago by "who knows".
After staring at it for a while, I dug right in and started welding in some metal to hold my corner in place, then started cutting.
The arm going up the windshield will be replaced too.  I marked the bad spots.
I'll probably have to replace the firewall before I put this side back on since I don't want to lose any more reference points by taking out my inner fenders.
« Last Edit: August 23, 2008 - 06:50:17 PM by shelbydogg »
Offline ShelbyDogg
« Reply #51 on: July 20, 2008 - 08:36:27 PM »
Spent all day slicing and dicing the cowl off.  I need to stop cutting things because now only a brand new cowl and firewall will do. This would be the only chance I have to put a new one in. Is it worth the $1100 though?
 I mocked up my used firewall and cowl side to see how it fits.   I also included a pic of the support brace that every convertible has in it's rocker  for strength.
Do you know the windshield's side support on a vert is different than on a hardtop? It is more rounded then covered with the side stainless molding. Now I will have to slice mine up the middle and round it off a little or the molding wont fit.
I have my new floors. The piece of tunnel is just in there as a referance point fo mounting the firewall. After it gets welded in, that old hump comes out.
« Last Edit: August 23, 2008 - 06:53:54 PM by shelbydogg »
Offline Jacksboys
« Reply #52 on: July 21, 2008 - 10:53:10 AM »
That is some major work you are completing.  Keep it up and that convert will look brand new.   :2thumbs:
Offline hemiken
« Reply #53 on: July 21, 2008 - 01:42:02 PM »
 :iagree: You have pulled some serious panels out of your way............... and to think, you were just looking for were the water leaked in from under the dash :poopoke: :smilielol: :2thumbs:
Offline sprecks
« Reply #54 on: July 21, 2008 - 08:01:18 PM »
I'll I have to say is WOW. I thought I did major surgery on my car. I was wrong. This is MAJOR surgery. Good luck. I'm sure it will be better than new when its done.
you can call me Jay
I've seen sicker dogs get well.
1971 Challenger Vert - 472 Hemi EFI
1969 Road Runner 440/Auto
2017 Ram Laramie 1500 - Hemi
Offline 71340RT
« Reply #55 on: July 23, 2008 - 01:32:53 AM »
Rob I may have to drive over and take a look at this Challenger vert as this is the only way to fully under stand what it takes to rebuild a car from the ground up that needs this much attention. Everything looks like it is coming along pretty fast and I wonder how you are handling working in the high heat and humidity?
Jeff
Offline The Cuda Guy
  • Support Our Troops
  • Pearl Harbor, HI
    • C-C.com
« Reply #56 on: July 23, 2008 - 03:41:54 AM »
Rob this thing is moving right along!  Do you think it will be done for Carlisle 09?  I know you mentioned you may or may not come next year.... but... I may or may not come to the NATs so...  But I will for sure make it to the Good Guys show that Tony's friends put on there in Ohio.
Bottom Line if that thing is done next summer I got to see it!!!
Don
Member Since January 14, 2002
Offline ShelbyDogg
« Reply #57 on: July 25, 2008 - 08:57:21 PM »
After working on the old replacement firewall, I decided only a new cowl and firewall will do.  I might as well go for it and stop wasting time patching my old one. How can I put in all new floors and not have a new firewall and cowl in my Pace Car!
« Last Edit: August 23, 2008 - 06:57:19 PM by shelbydogg »
Offline sprecks
« Reply #58 on: July 25, 2008 - 09:00:41 PM »
If you can't find anybody to get it closer to your place, I can get it back to central Illinois for you
you can call me Jay
Offline sprecks
« Reply #59 on: July 25, 2008 - 09:27:32 PM »
That's a good looking piece. Do they make the A/C version. I noticed the one you have pictured is the non-A/C.
you can call me Jay
