Author Topic: ShelbyDogg's 71 Challenger Pace Car (clone)  (Read 100492 times)
Offline Jacksboys
  • Here Since 08/28/06 GEORGIA
Re: ShelbyDogg's Pace Car (wannabe)
« Reply #75 on: August 22, 2008 - 01:00:23 AM »
So you decided to go with the 4-speed.   :2thumbs:   Looking good.
Offline Super Blue 72
    • Phil's Super Blue '72
« Reply #76 on: August 22, 2008 - 01:15:56 AM »
Supr job, Rob!  It's looking really sweet!  Keep up the great work!  :woo:  :thumbsup:  :ylsuper:
Offline CHUCKS71
  • "IF YOUR NOT FIRST YOUR LAST"
« Reply #77 on: August 22, 2008 - 05:01:41 PM »
Thanks guys, still a loooong way to go.
I love the look of a PISTOL GRIP in an E-Body.   People ask me about my pistol grip all of the time. The only way I'll leave it an automatic (with my 518) is if I can disguise the 4 speed shifter to look like a manual but have the slap-stik guts down below. That way I have the "LOOK" of Muscle when parked, but have the Auto-Overdrive on the highway.  Anything is possible with my welder.
The 4spd or any stick shift is the way to go!Looks like your making great progress Rob!From the pic's it looks like you got the correct rear floors did you get rid of the Goodmarks?
:burnout::22yikes::burnout:    www.ronpaul2008.com
71 Challenger 4spd   www.conservativepunk.com
03 Ram diesel 6spd    http://s105.photobucket.com/albums/m222/chucknutz/1971%20Challenger/
Offline Jacksboys
« Reply #78 on: August 23, 2008 - 01:03:46 AM »
I understand.  Either way, I am sure it will be a great car to drive.   :2thumbs:
Offline ShelbyDogg
« Reply #79 on: August 24, 2008 - 11:33:20 PM »
Worked 2 days to get the floor in. Drilled about 250 holes and hammered each one before welding it. Spent all day grinding each weld down.  The whole front floor, Firewall, and firewall sides are now completely welded in.
Big difference between this:
And THIS!
Next up;
Inner fenders!
« Last Edit: August 24, 2008 - 11:40:43 PM by shelbydogg »
Offline NoMope Greg
« Reply #80 on: August 24, 2008 - 11:46:25 PM »
To someone like me that doesn't know the first thing about welding, that is AMAZING!!  :eek2: :worshippy  :wow:
Greg
2003 Ford Escape XLS
Currently Mopar-less :(
Offline NoMope Greg
« Reply #81 on: August 25, 2008 - 11:37:14 AM »
So Greg, After seeing all the resto threads and seeing what a welder can do, don't you want to learn how to weld?  I started welding in a 6th grade summer school class, when I made a lamp.
It is easy to learn and Home Depot and Lowes sell Lincoln Mig welders.
Yeah, I want to learn and have considered buying a welder - I almost pulled the trigger on a cheap one at Harbor Freight one day - but for now, I need to spend my money on parts.  As an aside, many years ago I wrote down a list of ten goals I wanted to accomplish in my life and learning to weld well enough to do what you're doing was one of them.  The day will come...  :thumbsup:
Greg
Offline 'cudaCruiser
    • My '72 B5 'cuda
« Reply #82 on: August 25, 2008 - 05:57:04 PM »
Excuse my ignorance, but why hammer the holes?
Mickey
"The man who complains about the way the ball bounces is likely to be the one who dropped it." Lou Holtz
Offline ShelbyDogg
« Reply #83 on: August 25, 2008 - 08:31:32 PM »
No such thing as a dumb question on C-C.com.  When welding the thin floor layer to the thick frame layer, You have to use lots of heat to melt the frame below. If the floor metal isn't completely touching the frame  metal all the way around it's hole, the top metal will burn away due to too much heat. With full contact, I can weld right on the frame and slowly fiil the hole in a circle, hitting the thin metal at the same time with little raised weld to grind down.  Much of the floor had to be hammered to make it touch the frame.  I also had to start in the middle and work toward the sides to not buckle the floor.   The floor and firewall also had to be "metal worked" as they were mended together
Rob.
Offline ShelbyDogg
« Reply #84 on: August 26, 2008 - 02:31:06 PM »
Sitting at work, dreaming about what my car will look like. Had to fill my argon\co2 tank at lunch time, for welding tonight.  $65 was the price for an 80 tank! It used to be $15.
Found this pic on ebay. This thing will look sweet cruising around St. Louis!
Offline hemiken
« Reply #85 on: August 26, 2008 - 04:08:17 PM »
That does look way cool......................... 8)
Are you going to run the Keystones aswell ? :2thumbs:
Offline hemiken
« Reply #86 on: August 26, 2008 - 04:16:11 PM »
 :bananasmi i understand totally, would be nice with a little personal touch from you :2thumbs:
Offline ShelbyDogg
« Reply #87 on: August 28, 2008 - 11:52:02 PM »
IT"S OFFICIAL  This convertible will forever be a stick shift car.
I got it all cut out and welded in today.
 I also ordered my XV Motorsports Subframe connectors. I'm going to put them in at the same time I weld in my rear floors. It's logical that if I try to weld the rear floor in first, the angle will be off for the connector siince I can weld it in at a few different angles. If I put them in at the same time, they should go in with less grinding.
« Last Edit: August 30, 2008 - 10:01:05 AM by shelbydogg »
Offline hemiken
« Reply #88 on: August 29, 2008 - 06:02:46 AM »
 :wow: nice job................................................. :grinyes: :2thumbs:
Offline CHUCKS71
« Reply #89 on: August 29, 2008 - 04:20:38 PM »
:iagree: Nice job Rob!  :clapping:
