How can I flush my 727 transmission myself?
Author Topic: How can I flush my 727 transmission myself?  (Read 12798 times)
Offline NorthWestcuda
« on: May 07, 2008 - 01:12:44 AM »
I'm changing my trans oil & filter and would like to drain the oil out of the converter, but there is no way to get to the converter and drain it.  Should I try and flush it myself or can I with no special transmission tools?  If I can flush it myself can someone please explain how?
Thanks
« Last Edit: May 07, 2008 - 11:27:41 AM by NorthWestcuda »
1973 Cuda, 440 engine
1972 Chevy 4x4 PU stepside
2003 Ford F-350 Diesel
Re: How can I flush my 727 transmission myself?
« Reply #1 on: May 07, 2008 - 02:04:13 AM »
is there a drain plug on the front face of the converter ? Some had them others didn`t
« Reply #2 on: May 07, 2008 - 09:44:18 AM »
There is no way to tell if there is a plug or not.  When I take the inspection plate off the front of the trans all I see is the flexplate. Is'nt that typical for the 727 A's?
« Last Edit: May 07, 2008 - 11:29:08 AM by NorthWestcuda »
« Reply #3 on: May 07, 2008 - 11:38:03 AM »
as you rotate the flex plate & converter around the threaded 1/8" pipe plug will become visible between 2 of the bolts if it has a drain
Offline tactransman
« Reply #4 on: May 07, 2008 - 12:42:55 PM »
Drain plug will be dead center of the converter bolt pads if it has one. Here is a pic with the drain plug in between the balancing weights that just happen to be on this pic.
Terry-tactransman
Union, Mo.
« Reply #5 on: May 07, 2008 - 09:27:49 PM »
Thanks for your feed back so far.
  I’ve included two pictures on what I’m dealing with.  I’m sure both of you have seen these pictures a thousand times.  But, I don’t understand how I can even look for a plug when I can’t even see the weights on the torque converter.  The whole torque converter is covered by the gold colored “flex plate” I call it, except for the teeth.  Is this typically what you find?  BTW it’s a 73 cuda.  :1zhelp: :clueless:
« Reply #6 on: May 08, 2008 - 02:25:41 AM »
aftermarket B&M flex plate , these leave no room to get the drain plug out if it has one
Offline tactransman
« Reply #7 on: May 08, 2008 - 08:31:15 AM »
Here is the other thing you can do.
Drop the pan,change your filter and pan gasket.   :working:
Add 4 qts of new fluid to the trans, with 8 qts ready (2 one gallon jugs not 8 one quart bottles)
Remove the REAR cooler line,put a pan under it with a piece of hose on the cooler line aiming at the pan.
Start it up in NEUTRAL,add the fluid thru the filler tube as the old pumps out the rear line into the pan.
When the fluid coming out is clean (or the two jugs are used up) shut it off and hook it all back up.
Top off the trans fluid idling in NEUTRAL
You have now done what I call "A poor man's transmission flush".  :lol:
Terry-tactransman
Union, Mo.
Offline wally426ci
    • maryland mopars
« Reply #8 on: May 08, 2008 - 10:20:32 AM »
 :popcorn:
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Offline quagmire
  • Traction Impaired......
« Reply #9 on: May 08, 2008 - 07:44:34 PM »
I second that, it works great and does for the most part the same thing as a flush machine that costs $10K.  Just make real sure to never let the pump run dry from getting low or introduce too much air into it as you pour the new fluid in.
Offline DAYLEY/CHALLENGER
« Reply #10 on: May 08, 2008 - 08:00:43 PM »
And the main reason to want to flush the system I know is to refresh the fluid but can it help with the harshnes of shifting also?
Dave or David
« Reply #11 on: May 08, 2008 - 08:39:51 PM »
It sounds like you have an issue with the kick-down linkage. Too forwardly placed on the carb stud, and that will do it. I have the opposite problem. I had to place a screw in the back of my linkage slot to the carb, so I could shift harder. I was in 3rd gear at 10 MPH before.  :eek4: I guess I'm shifting from 1st to 2nd at 2000 RPM+ now. It depends on how much I get on it. I can post a pic if you want tomorrow. By the way, I have a Trans-Go shift kit, so it is made to shift hard and snap my neck.    :ylsuper:
Offline wally426ci
    • maryland mopars
« Reply #12 on: May 10, 2008 - 08:26:58 AM »
Mike,
my father and I had to do the SAME exact thing!!!  :burnout:
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
