Author Topic: dumb question but need help!!!  (Read 1591 times)
Offline 4THECHALLENGE
« on: May 08, 2008 - 02:06:20 AM »
how many crossmembers do i need? is there 1 kind or 2 different ones?? i have a 929 trans . sorry this is my first mopar
Re: dumb question but need help!!!
« Reply #1 on: May 08, 2008 - 02:24:45 AM »
I assume you are talking about the trans crossmember ?
 the Chall used the same crossmember for all trannys
« Reply #2 on: May 08, 2008 - 02:29:11 AM »
yes correct ..so i only need one crossmember right?
« Reply #3 on: May 08, 2008 - 11:09:32 AM »
yes , if I rememeber right the 70 is different from all other years in the bolt pattern also
« Reply #4 on: May 09, 2008 - 07:19:28 PM »
i bought one of ebay it reads 70-74 mine is a 74 but in cloning a 70 , will that matter ??
Offline NoMope Greg
« Reply #5 on: May 09, 2008 - 08:09:10 PM »
Unless you want to get underneath and re-do the bolt pattern  :grinno:, you'll want the '74 crossmember.  If you have one, stay with what you have.  If not, get the appropriate crossmember.
Greg
2003 Ford Escape XLS
Currently Mopar-less :(
« Reply #6 on: May 09, 2008 - 08:12:45 PM »
are you serious?? i alresdy bid on it and it reads 70-74 hmm?? how hard is it to redo  the bolt patter ? i dont have one at all.
Offline NoMope Greg
« Reply #7 on: May 09, 2008 - 08:22:53 PM »
I should clarify - if Chryco thinks the bolt pattern was different on a '70 than on '71-'74, it may well be - he is the guru around here.  :worshippy  I don't know for sure - I have a '70 with a manual trans.
If you win it, hold onto it until you can match it to your car.  If it works, keep it.  If it doesn't, e-bay it to re-coup some of your money and then find the right one.  If you already have a crossmember and they both fit, keep the better one and offer the other one here or put it back up on e-bay.  I rather suspect that if the patterns are different, trying to change it will not be worth the time.  After all - it's a clone, not the real thing and no matter how much you change it, it won't change the value of the car and you'll never know the difference between the two crossmembers when you're driving it.
If I can offer a little friendly observation/suggestion - you've mentioned several times that you're new to Mopars (welcome!)  and have a lot to learn.  My suggestion is to give yourself time to learn.  Why not restore what you have - a '74 - to allow you to learn about the cars and then work on making the changes to a '70 clone.  Of course, you've already changed the tail panel...
Greg
« Reply #8 on: May 09, 2008 - 08:33:00 PM »
good advice but the car i bought came with a 1970 grill and a rear panel already welded, a 340 motor with 0 miles on rebuild, a 9?? tranny with 0 miles on the rebuild, and alot of stuff but most of the 74 body parts are gone :walkaway:
Offline Challenger6pak
« Reply #9 on: May 09, 2008 - 10:14:36 PM »
They are different between 70 and other years.  It will be easiest to use the one that would be for your car; the 71-74 version.
« Reply #10 on: May 10, 2008 - 01:28:30 AM »
thanks u all for the heads up ..i went to get my harness (engine harness) it was in the truck and guess what i see?? my crossmember!! yey!! :clapping: now i have to talk my way out of the one i bought on ebay for 25 dollars
« Reply #11 on: May 10, 2008 - 09:02:43 AM »
The Ebay seller has expenses in listing and ending fees.  They can't be more than a few dollars for a transaction that small.  As a seller on Ebay, I have had people change their mind after they won an item.  They have offered to pay the fees and end the transaction.  Maybe your seller will except the same offer.
Offline hemiken
« Reply #12 on: May 10, 2008 - 09:16:18 AM »
Or you could finalize the E-bay transaction and re-offer the crossmember here on C-C.com incase someone else here is after one. :2thumbs:
« Reply #13 on: May 10, 2008 - 04:14:07 PM »
i sent him an email and he hasnt replied thanks fir the heads up guys. i would keep it but im out of room as it is
