Author Topic: what am i missing ??  (Read 2457 times)
Offline 72bluNblu
Re: what am i missing ??
« Reply #15 on: May 08, 2008 - 05:33:51 PM »
In addition to the headlight buckets is it required to change out the physical inner fender structure as well?
I don't think so, but to be honest I haven't seen the inside of both fenders in person.
Offline 4THECHALLENGE
« Reply #16 on: May 08, 2008 - 07:58:35 PM »
hmm ive emailed some people on them well see what happens. any1 else doing the same thing ?
Offline Super Blue 72
    • Phil's Super Blue '72
« Reply #17 on: May 08, 2008 - 08:14:16 PM »
Could consider fiberglass, may be cheaper as far as $$$?  I dunno... :dunno:
« Reply #18 on: May 08, 2008 - 08:18:02 PM »
hmm?? this sucks ill have to wait tilll payday unless i can come up with a homemade solution
Offline 72bluNblu
« Reply #19 on: May 08, 2008 - 08:32:34 PM »
The fiberglass buckets are only 40 bucks each, but as I mentioned before you'd have to figure out how to mount them...
« Reply #20 on: May 08, 2008 - 08:43:08 PM »
DO U HAVE A LINK ??
THNKS MAN  :cooldancing:
Offline 72bluNblu
« Reply #21 on: May 08, 2008 - 08:59:12 PM »
I actually posted it above already, but here it is again
http://www.up22.com/index.htm
Mounting them might not be so simple though, and as I mentioned earlier you'll still need a few more parts to make it work.
Offline 72hemi
  • MEMBER SINCE JANUARY 2006
« Reply #22 on: May 08, 2008 - 09:03:21 PM »
I bought my hood from unlimited products (www.up22.com) and the quality was crap and it didn't fit at all. others on here have had similar results.
1996 Dodge Viper GTS Coupe
Offline 72bluNblu
« Reply #23 on: May 08, 2008 - 10:20:06 PM »
Yeah, I've seen other reviews of their stuff that was less than impressive, including the headlight buckets, which I mentioned earlier. On the other hand, if you don't have 300 bones for a metal pair, its at least some kind of option.
Since its fiberglass and mostly not visible, you could probably "make them fit" and strengthen them up if need be and still come out ahead on price, fiberglass is pretty cheap.
Obviously if "show" quality is needed the only way to go is a metal pair, either new or from a "patch" quality set of old fenders.
« Last Edit: May 08, 2008 - 10:22:03 PM by 72bluNblu »
« Reply #24 on: May 08, 2008 - 10:47:48 PM »
SO I LOOKED AT THEM AND I THINK ITS THE BEST WAY TO GO ..IM BUILDING A DRIVER SO FOR NOW THOSE WILL DO, MEANWHILE ILL DECIDE WHETHER I GET NEW FENDERS, REPROS OR WHAT EVER COMES. MONEYS TIGHT SINCE IM IN DIVORCE PROCEEDINGS.
THANKS 4 THE HELP ..ANYONE KNW IF ANYONE ELSE HAS DONE THIS ?
Offline 72bluNblu
« Reply #25 on: May 08, 2008 - 11:42:47 PM »
Its been done more than a few times, I've seen a couple examples in pictures on the web. Bananaskin has a car that was set up this way by a PO and has converted it back, not sure if anyone else on here has done it. Its really just a matter of getting all the front end parts to swap the grilles,the headlights are the only tricky part for that. But to be 100% you'll have to weld in a new tail panel and side marker mounts, which is a pretty time consuming/costly procedure.
« Reply #26 on: May 09, 2008 - 12:54:17 AM »
i already have the tail welded  :cooldancing:
