Author Topic: Tach Needle Thinks Its The Turn Signal  (Read 978 times)
Offline JeffAARy
  • Orange Mopars Drive Me Wild
« on: May 08, 2008 - 11:30:27 AM »
My tach works, but when the turn signals go on the tach needle swings back and forth.  Is this a short somewhere or miswiring?  Originally this car, a 1971 Cuda, had a standard dash.  A previous owner put in a 1972+ rallye dash.  I haven't checked yet, but I think they brought over the rallye dash harness (has four dash illumination lights, although they could have spliced one in).
If its a problem with the circuit board, no problem - I'm upgrading to the rt-eng tach board anyway.
Ideas?
Offline vinb
Re: Tach Needle Thinks Its The Turn Signal
« Reply #1 on: May 08, 2008 - 11:40:06 AM »
Maybe it could be the voltage limiter that plugs into the back of the cluster..
Offline JeffAARy
« Reply #2 on: May 08, 2008 - 11:52:49 AM »
That would be nice, as I'm upgrading that with an rt-eng version also.
Swedefish
« Reply #3 on: May 08, 2008 - 01:41:08 PM »
Bad ground for the instrument panel?
Offline JeffAARy
« Reply #4 on: May 08, 2008 - 02:16:50 PM »
I don't think the entire panel is poorly grounded.  The gauges all work, as do the lights.
Offline 71 DEPUTY
  • IF YOU CAN'T DODGE IT--RAM IT!
    • Cardomain
« Reply #5 on: May 08, 2008 - 04:18:29 PM »
I would say a bad ground too- it's the only thing they share. run a ground wire from the back of the metal dash to the dash frame.
« Reply #6 on: May 08, 2008 - 06:52:13 PM »
My only question is where he came up with a power source for the tach. if this is a standard harness. Maybe he tapped into something he shouldn't have?  :screwy: This is a good one. Your tach is not the problem if it works fine otherwise. Wiring can be a bear to figure out after a bunch of owners have messed around before you.   :pullinghair:
Offline JeffAARy
« Reply #7 on: May 08, 2008 - 09:29:25 PM »
Yeah, miswiring of a standard harness is what I'm afraid of.  I was hoping this was a common problem and that someone would know right off the top of their head.  As usual with electrical problems it could be anything, or my personal favorite - multiple problems that cause misdiagnosis.
