Author Topic: 400 stroker?  (Read 1091 times)
Offline 73dce
400 stroker?
« on: May 08, 2008 - 07:59:32 PM »
I have a 400/727 sitting in my garage and was wondering what I would need to do to make my Challenger ready for a big block, it now has a 318 in it.  I have a mechanic that says he will build it to about 500 hp for me for pretty cheap.
Offline Super Blue 72
    • Phil's Super Blue '72
Re: 400 stroker?
« Reply #1 on: May 08, 2008 - 08:23:18 PM »
Things off the top of my head (I'm sure others can add to this list...)
-bigger radiator
-thicker torsion bars
-reconfigure distributor wiring as BB dist is in front
-motor mounts?
 :dunno:
Re: 400 stroker?
« Reply #2 on: May 08, 2008 - 08:50:18 PM »
You might get away with a 22" radiator. I'm assuming that is what you have, but if you have A.C., then you would need a 26".
Otherwise... I agree with Super Blue 72.   :grinyes: Some might go to a 3/8" fuel line, but I get by fine with the 5/16" and a Hi-Volume mechanical fuel pump.
Offline 73dce
Re: 400 stroker?
« Reply #3 on: May 08, 2008 - 10:12:45 PM »
So it wouldn't cost too much.  Just little things here and there.  I don't know, I'll have to price some stuff and see where it lands me.  It's either going to be this or the XV susp. upgrade.  Then later down the road maybe the other. :bananasmi
Re: 400 stroker?
« Reply #4 on: May 09, 2008 - 04:52:05 AM »
I guess it all depends what you want now.  Whether you want to carve corners or if you want more "umph" when you hit the gas.
You could go with the XV then do some mild mods to the 318 (if you haven't already) that may not cost too much $$$.  :dunno:
nivvy
Re: 400 stroker?
« Reply #5 on: May 09, 2008 - 05:23:21 AM »
451 strokers rock..........  :working:
Re: 400 stroker?
« Reply #6 on: May 09, 2008 - 05:25:32 AM »
Your avatar rocks!  :thumbsup:  (Sorry, off topic.....  :misbehaving: )
Who is she if you don't mind me asking?  More pics? Hope your previous gal isn't pissed!  :roflsmiley:
Offline moper
Re: 400 stroker?
« Reply #7 on: May 09, 2008 - 11:51:35 AM »
You need a radiator that will cool 500hp, and the engine mount ears. You will need to extend a couple wires for the temp sender and distributor wires. No need for torsion bars. The 318/3832bbl used the same bars. A B wedge in stock form is only about 100lbs heavier than a fully stock dressed LA V8. The /6 is heavier..
Offline Changin Gears
Re: 400 stroker?
« Reply #8 on: May 09, 2008 - 12:17:32 PM »
A four bbl throttle cable is longer than the 2.
Offline moper
Re: 400 stroker?
« Reply #9 on: May 12, 2008 - 12:02:51 PM »
Yeah, but they still work. Even with tall RB intakes. You just need the right throttle bracket. It's the kickdown that gets dicey.
