Author Topic: INSTALLING A 340 AND A 904 TRANNY HELP!!!  (Read 7150 times)
Re: INSTALLING A 340 AND A 904 TRANNY HELP!!!
« Reply #15 on: May 10, 2008 - 02:59:12 AM »
340 steel cranks are internally balanced & do not have a weight on the converter so if it has one remove it , if the 340 is a cast crank you need a weight on the converter
Offline vinb
« Reply #16 on: May 10, 2008 - 10:46:04 AM »
Nothing wrong with a good 904, in fact they much lighter and are about .15 quicker at the track. Also you can find a low gear set in the junker very cheap. 727 low gears are pricey.. Valve bodies are the same in both units...
I wouldn't worry about breaking it because alot of Stock Eliminator guys and bracket racers been using them for years.
Big Block guys don't have that option they have to use the big trans..
Both are great transmissions....
Offline tactransman
« Reply #17 on: May 10, 2008 - 10:51:58 AM »
When I asked about installing a 727,I didn't know you already had the 904 rebuilt. Get the right converter for the right engine,make sure your throttle pressure (kickdown) is adjusted right and you should be fine. :cheers:
Terry-tactransman
Union, Mo.
Offline 4THECHALLENGE
« Reply #18 on: May 10, 2008 - 04:12:26 PM »
but how do i know if i have a steel or cast crank?? help
Offline 422STROKER
  • Member Since 6/3/06
« Reply #19 on: May 10, 2008 - 06:06:15 PM »
Give us a picture of your balancer.
Tom :2thumbs:
Tom
Offline tactransman
« Reply #20 on: May 10, 2008 - 08:03:53 PM »
Tom :2thumbs:
As long as the balancer is the correct one too! :bricks1:
Terry-tactransman
Union, Mo.
« Reply #21 on: May 11, 2008 - 12:51:42 AM »
the balancers of a 318 will that help?
Offline hemiken
« Reply #22 on: May 11, 2008 - 03:28:47 AM »
No :grinno:
I suggest you post a picture of the crank even if it is sitting in a block, just take the sump off.   :picture: :2thumbs:
Offline 422STROKER
« Reply #23 on: May 11, 2008 - 09:38:50 AM »
They could have used the 318 balancer for a nuetral balance if it was done right.
Tom :2thumbs:
Tom
« Reply #24 on: May 11, 2008 - 05:27:16 PM »
wiill doo as soons as im able too ,thanks all
Offline tactransman
« Reply #25 on: May 12, 2008 - 11:58:26 AM »
Here is a good pic to show the difference on the crank itself. (big blocks and small blocks basically the same)
Terry-tactransman
Union, Mo.
« Reply #26 on: May 12, 2008 - 09:04:47 PM »
thank uyou guys im hoping tomorrow i can get the motor transfered to my brothers home for further inspactions. by the way does anyone know how to post pics??
thanks a million  :working:
Offline NoMope Greg
« Reply #27 on: May 13, 2008 - 12:56:09 AM »
To post pics, reply, then below the box where you type the message, click "Additional Options."  There will be an option to attach files with a browse button.  Browse to the folder on your computer that has the photos and click the one you want.  By clicking "more attachments", you can add up to ten.
There's a way to add photos that you have online at another site, like Photobucket or Flickr, but I'm not sure how that's done.  Someone else can instruct us both on that.
Greg
2003 Ford Escape XLS
Currently Mopar-less :(
« Reply #28 on: May 14, 2008 - 01:33:27 AM »
thanks guys today i insta;lled the grill but no headlighs (need the buckets) also i cleaned ouut the interior and gutted the bad stuff. will post pics soon
