Author Topic: Holes on inside wheel wells  (Read 842 times)
Offline blown74
  • Never go less then 60 MPH in Reverse! Bel Air, Md
« on: May 09, 2008 - 05:24:58 PM »
I have 4 holes on the inside wheel wells ( 2 on each side). Are they from the factory and were they covered with rubber flaps?
American Muscle Rocks !!
Offline FY1443433
  • 1971 Superbee, 1970 Challenger R/T
Re: Holes on inside wheel wells
« Reply #1 on: May 09, 2008 - 05:48:47 PM »
Blown74,
These are access panels to adjust your caster and camber when you doing a front end alignment.
The front two should have a metal plate with screws holding them on from the outside.
You are correct about the rubber flaps.  They are attached by spring clips from the outside.
FY1
Offline blown74
« Reply #2 on: May 09, 2008 - 10:55:30 PM »
Crap didn't think they were for that.  :banghead: I'm assuming one can still adjust the caster and camber if these holes are closed off??? From inside the hood.
Offline FY1443433
« Reply #3 on: May 10, 2008 - 09:28:43 AM »
It will make it more difficult, but it can be done.
FY1
Offline Rare_T_A
    • Freiss Family Mopar Site
« Reply #4 on: May 10, 2008 - 12:56:29 PM »
This is my 70 Challenger. These are the factory holes on both sides.
'09 Challenger R/T  5.7 HEMI Auto
'70Challenger T/A 340 727
Fargo, N. Dak.
My web Site:  http://freiss.co.nr
My Flikr Page: http://www.flickr.com/photos/102813164@N04/
I was born with nothing and I still have most of it left!
craigsmytcudas
« Reply #5 on: May 10, 2008 - 02:31:00 PM »
hey whats the white pooky along the seams for jus courious thanks
Offline blown74
« Reply #6 on: May 10, 2008 - 08:54:57 PM »
2 part epoxy just trying to hide the seams a bit. Not sure how well its going to work. I welded 16 guage plate steel to the outside of the wheel well then applied some bondo to the inside to make it smooth. Just put a second layer on today. Maybe I should have just left the holes alone, but my neighbor thought it would look cleaner if I closed them up. What was I thinking??  :banghead:
