Author Topic: 71 engine harness  (Read 1276 times)
Offline 71cudda
71 engine harness
« on: May 10, 2008 - 10:55:54 AM »
installed new engine harness, topclip on alternater w/ blue/blue& white wire heated up and started smoking seems to be the same wire that started the problem im pretty sure harness is installed correctly, do you think it is the alternator. also there are two wires right next to alternotor clips with metal connectors brown and grey i believed would have gone to ignition , but i taped them off as i am running msd ignition , was this correct
Re: 71 engine harness
« Reply #1 on: May 10, 2008 - 11:41:12 AM »
yes I think it is the alternator , probably a shorted diode take an Ohm meter & see if the terminal is shorted to ground
Offline 71cudda
« Reply #2 on: May 10, 2008 - 01:31:18 PM »
i just realized i did not connect the ballist wires together would this make the alternator overcharge
Offline 71cudda
« Reply #3 on: May 10, 2008 - 01:43:30 PM »
are those two wires that you said to connect to the red msd wire off the engine harness or if i just replaced the harness [where it was already msd egnition and up and running] are they already in place because when i removed the old harness, i didnt have to remove anything from the msd system     thnks for your help
« Reply #4 on: May 12, 2008 - 01:52:42 AM »
thr 2 wires to connect are the Brown & dk blue at the ballast , the MSD comes with a pigtail already made to plug in & no it will not have an affect on the alternator charging
