Author Topic: MP electronic distribuitor swap  (Read 2913 times)
sleepychallenger
« on: May 10, 2008 - 01:03:10 PM »
i am going to get the MP electronic distribuitor kit this week and was wondering if anyone has any advice on putting this in? summit said something about needing a voltage regulator too???  :feedback:
Offline Katfish
  • 70 Challenger
Re: MP electronic distribuitor swap
« Reply #1 on: May 10, 2008 - 01:06:42 PM »
No need to change your VR.  The instructions are pretty straight-forward.
I would suggest getting 1 of the module brackets, this will keep it cooler and you won't get the "death ooze".
Offline CrazyPete
« Reply #2 on: May 10, 2008 - 02:06:18 PM »
i totally agree its very simple
1970 Dodge Challenger T/A      http://heartlandmopars.com
1970 Plymouth Barracuda Gran Coupe
1976 Dodge Dart Sport
"Is that an oil leak?  No it's just sweat from all that HORSEPOWER"
sleepychallenger
« Reply #3 on: May 10, 2008 - 05:47:21 PM »
where do i get a modual bracket? can i get that from summit too? where should i mount the box?
Offline Katfish
  • 70 Challenger
« Reply #4 on: May 10, 2008 - 08:10:04 PM »
Most people put the box on the firewall, passenger side near top.  That's where mine is.  Look at other engine compartments and decide what you like.
I'll have to look around, been awhile since I bought my bracket.  Here's something specialized, but you get the idea.  The bracket keeps the module off the firewall keeping it cooler.
http://cgi.ebay.com/ebaymotors/MOPAR-Big-Block-ECU-Bracket-PROBLEM-SOLVER-Dodge-440-70_W0QQcmdZViewItemQQ_trksidZp1638Q2em118Q2el1247QQcategoryZ34202QQihZ006QQitemZ160229110492QQrdZ1QQsspagenameZWD1V
« Last Edit: May 10, 2008 - 08:31:04 PM by Katfish »
« Reply #5 on: May 12, 2008 - 02:19:20 AM »
use some di-electric grease on the bolts holding the ECU on so the ground stays connected
Offline MDMoparDude
« Reply #6 on: May 12, 2008 - 12:24:53 PM »
I was going to mount my ECU to the bottom of the battery tray where it cannot be seen.  I will have to extend the wires though.  Would this cause any forseeable problems?
« Reply #7 on: May 12, 2008 - 12:48:16 PM »
I see that done all the time with no issues
sleepychallenger
« Reply #8 on: May 12, 2008 - 12:49:31 PM »
can someone post some pics of this?
Offline MDMoparDude
« Reply #9 on: May 12, 2008 - 01:47:58 PM »
I wont be able to get picks until this weekend.  All I did was just drill 2 holes in the bottom of the tray to correspond to the mounting holes on the ECU.  You will have to extend the wires, but you could tie them with the front wiring harness.  I believe Jims auto parts sells the tape.  You cannot see it unless you are really looking for it.
Offline moper
« Reply #10 on: May 12, 2008 - 02:02:56 PM »
Just be VERY sure the grounds stay clean and good. I would not use the factory type module under the tray for that reason. I clean the metal bare, use the dielectric grease like CP, and in some cases run a seperate ground strap to the block. The better the ground, the less likely of having issues in rain or humid weather in a year or two.
« Reply #11 on: May 13, 2008 - 12:53:10 AM »
ususally they are mounted on the inner fender under the tray not onto the underside of the tray , if you are using a Gel battery no issue but if you  use a acid type you could have problems with corrosion etc
Offline FM3V6M
  • TX9 383 4spd
    • mytx9cuda
« Reply #12 on: May 13, 2008 - 11:59:54 AM »
Why don't you go with the Pertronix unit, it's totaly stock appearing under the cap and no ECU to worry about? Uses the stock distributer too!
sleepychallenger
« Reply #13 on: May 13, 2008 - 12:10:09 PM »
i had the ignitor system on my car before the fire, but after the fire, it totally fried. just figured that i would go this rout this time. also, this route comes with the vacuum advance, mine is toast from the fire.
« Reply #14 on: May 14, 2008 - 02:04:29 AM »
make sure you take a look to see where the dist is pointing Before pulling the dist out
