Author Topic: What rockers would you recomend for Victor heads...............................?  (Read 1377 times)
the Comp rockers are not bushed or needle brg they are just bored to correct size
the STR can work on a auto car but still is not the best choice , A high stall converter may actually hurt you as the engine will generally bog on laubch if not loaded up first & fuel tends to sit inside the intake , it drops out of the no flow zones & pools in the dead spots , far from ideal
