Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
The Rest of the Tech
(Moderator:
Chryco Psycho
Fan Shroud-Which end is up?
« previous
next »
Print
Pages: [
1
Author
Topic: Fan Shroud-Which end is up? (Read 1010 times)
troutstreamnm
Sr. Member
on:
May 11, 2008 - 03:35:10 PM »
So I'm doing a mock up of my aluminum radiator and shroud in the car and can't remember if the narrow (2") side or wider (3") portion of the shroud is up. I started to put the wider end on bottom, but figured it would be good to check here before drilling any holes. Any help
Thanks.
Logged
08 SRT-8 Challenger
71 GA4 Challenger
70 FK5 Charger 500
422STROKER
Sr. Resident
Member Since 6/3/06
Re: Fan Shroud-Which end is up?
Reply #1 on:
May 11, 2008 - 03:49:13 PM »
I got to do mine soon. I would guess that since the engine is on a slight uphill, that the lower side would be smaller, does that make sense?
Tom
Logged
Tom
troutstreamnm
Sr. Member
Reply #2 on:
May 11, 2008 - 04:13:36 PM »
If you put the wider side up, it provides a bit more coverage over the fan blades for air flow and more protection from the rotating blades. I have pics, but I can't tell from the angles I have. Anyone know for sure?
Logged
08 SRT-8 Challenger
71 GA4 Challenger
70 FK5 Charger 500
422STROKER
Sr. Resident
Member Since 6/3/06
Reply #3 on:
May 11, 2008 - 04:16:46 PM »
What set-up do you have? Any pics?
Tom
I got the northern radiator shroud. IIRC it is the same top and bottom though.
Logged
Tom
troutstreamnm
Sr. Member
Reply #4 on:
May 11, 2008 - 04:49:58 PM »
I'm installing a Smith's aluminum radiator and the stock (factory) fan shroud. Here are a couple pics, the first two are with the narrow side up, the last two with the wide side up. I did notice that with the wide side up, the Chrysler pentagon and part numbers are upside down.
Logged
08 SRT-8 Challenger
71 GA4 Challenger
70 FK5 Charger 500
422STROKER
Sr. Resident
Member Since 6/3/06
Reply #5 on:
May 11, 2008 - 08:24:52 PM »
The last 2 look right.
The indents are for the stock top tank.
Tom
Logged
Tom
troutstreamnm
Sr. Member
Reply #6 on:
May 11, 2008 - 10:01:05 PM »
O.K. thanks for the input Tom
Logged
08 SRT-8 Challenger
71 GA4 Challenger
70 FK5 Charger 500
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
