Author Topic: ONE WIRE ALTERNATOR  (Read 12721 times)
Offline 71cudda
ONE WIRE ALTERNATOR
« on: May 11, 2008 - 07:40:31 PM »
CAN SOMEONE EXPLAIN THE ONE WIRE ALTERNATOR CONNECTION TO ME. DOES THIS BYPASS REGULATOR AND HOW DO YOU CONVERT WIRING. IF I NEED A NEW ALTERNATOR, IS THIS A GOOD WAY TO GO    ALSO CAN YOU PUT TOO BIG OF AN ALTERNATOR IN     THANKS
Offline GoodysGotaCuda
Re: ONE WIRE ALTERNATOR
« Reply #1 on: May 11, 2008 - 08:59:27 PM »
Here is a write-up on 1-wire alternators, these guys don't speak too highly about them.
http://www.madelectrical.com/electricaltech/onewire-threewire.shtml
Absolutely you can put 'too big' of an alternator in. The factory alternator can even push the limits of the old 10gauge wiring. I have 6gauge wiring from my 90amp alternator. 'Too big' is figured from your wiring out of the alternator to the battery.
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline 71cudda
« Reply #2 on: May 11, 2008 - 09:54:03 PM »
thanks for the link that explains alot  do you think a 75 amp alt would be a problem
« Reply #3 on: May 11, 2008 - 10:01:47 PM »
The maximum rating for the factory 10gauge wiring is 55amps. That is a fairly long circuit so you can probably lower that by a few amps, also adding how old the connections and wire itself are, even lower. I would suggest that more than stock output could cause an issue. I would say your best bet would be to have 8ga straight to the starter relay or battery +.
1976 Dodge Warlock
Offline 71cudda
« Reply #4 on: May 11, 2008 - 10:13:03 PM »
what did you run the 6 gauge in place of  from where to where
« Reply #5 on: May 11, 2008 - 10:17:14 PM »
I ran 6gauge wire due to i have a 90amp alternator and the 6 gauge is thicker than 8 or 10, therefore it'll hold more current.
My battery is in the trunk, i run 6ga from the alternator output stud, to a 100amp circuit breaker, to the battery positive terminal.
1976 Dodge Warlock
Offline 71cudda
« Reply #6 on: May 11, 2008 - 10:21:05 PM »
would i just clip the one with the nut off and run 6 gauge from ther to the battery with a circuit breaker and all other connections would stay the same
« Reply #7 on: May 11, 2008 - 10:42:32 PM »
I would go this route here. Changing the alternator output wire then makes your factory ammeter useless. Given charging voltage is something you definately want to keep an eye on, installing a volt gauge is how you would then monitor that.
http://www.madelectrical.com/electricaltech/amp-gauges.shtml
Your factory setup is like this
you would be modifying it to this, however using a larger alternator output wire
1976 Dodge Warlock
« Reply #8 on: May 12, 2008 - 02:01:22 AM »
 :iagree: run a wire to the starter relay
Offline blown74
  • Never go less then 60 MPH in Reverse! Bel Air, Md
« Reply #9 on: May 12, 2008 - 02:03:46 AM »
Am I missing something on Diagram B? Is a 14 guage fusible link suffiecient to handle all the current from the alternator? 14 gauge 12 volts I'm figuring 20 -25 amps max?? Going larger is usually better. One advantage less loss. Disadvantage more cost.
American Muscle Rocks !!
« Reply #10 on: May 12, 2008 - 07:21:51 AM »
Actually its in the 30-40amp range off the top of my head, again that diagram is for a factory system. Which in most cases doesn't draw that many amps so it should work out just fine. Aftermarket headlights, ignition, stereo, fuel pump, electric fan, etc starts to add up quick. Which is why i have a 100amp circuit breaker in my charging circuit and 6ga wire.
1976 Dodge Warlock
Offline hotrodded1970
« Reply #11 on: February 26, 2009 - 09:32:31 PM »
Goodie how did you figure how big of a circuit breaker you needed, i have a 100 amp alt im gonna put in but not sure how high a breaker i should place in line. Any info?
Proud Owner Of a Numbers Matching One Owner 28,000 orginal Miles 1970 Challenger 383. Oh yeah Miles Documented
Offline mopar12372
    • mopartech
« Reply #12 on: March 04, 2009 - 10:47:09 PM »
the only avantage to using a 1 wire alternater is the wireing. why would you convert a purfectly good 4 wire denzo alternarter to a 1 wire(the wireing isnt that hard)? only to have your battery over charged most of the time.
RESTO PICTURES
nivvy
« Reply #13 on: March 05, 2009 - 05:24:57 AM »
not if your batteries in the trunk and wanna pass tech  :stirpot:
Offline Aussie Challenger
« Reply #14 on: March 06, 2009 - 03:53:14 AM »
  A one wire system has the regulator built into the alternator, removing the regulator would fry the battery and electrics very quickly.    :faint:
  A 12v alternator can put out 30 volts very easily if un regulated, aske me how I know?   :bigsmile:
