Author Topic: 70 Booster and master picture wanted  (Read 1208 times)
Offline Tropicalcats
  • Don't Ever, Ever Give Up
« on: May 11, 2008 - 09:29:30 PM »
Looking for a couple good pictures of a original 70 Challenger power booster and master cylinder mounted in a car.
 Thanks
SOLD
Alaskan_TA
Re: 70 Booster and master picture wanted
« Reply #1 on: May 11, 2008 - 09:34:20 PM »
« Reply #2 on: May 11, 2008 - 09:36:15 PM »
Barry, that big hole with the rubber tube coming out of it, is that for a foot washer pump? What goes there if not? My car had a variable , but that hole is there to
Alaskan_TA
« Reply #3 on: May 11, 2008 - 10:04:46 PM »
Yes, this is a manual washer car.
If I remember right, a power washer car would just have a plug in that hole?  :dunno:
« Reply #4 on: May 11, 2008 - 10:16:13 PM »
Thanks Barry
SOLD
Alaskan_TA
« Reply #5 on: May 11, 2008 - 10:18:45 PM »
My pleasure TC, did it tell you what you needed to know?
The master cylinder itself would have been black also when new, the whole assembly was painted at the same time, all together. (for 1970 model year cars)
« Reply #6 on: May 11, 2008 - 10:36:56 PM »
It sure did. just wanted to see how the wire was wrapped through. Wish I had the original Master.
SOLD
« Reply #7 on: May 11, 2008 - 11:12:50 PM »
Give me the part number for the master. I have a master in a drawer in the shop. I will see if it is the one you need. If so, you can have it.
Offline PlumCrazy
« Reply #8 on: May 11, 2008 - 11:13:40 PM »
Non T/A - AAR booster
« Reply #9 on: May 12, 2008 - 07:02:38 AM »
 Alan I sent you a PM
SOLD
« Reply #10 on: May 12, 2008 - 08:02:39 AM »
I will check it out now for you. I am going to try and lift the dana into my dually right now, so I will be in the shop. If it is the one you need, it's not forsale, you can have it.
