Author Topic: 340....how much hp can be "easily" reached with a 340.  (Read 2180 times)
Offline 351c4v71
« on: May 11, 2008 - 11:31:09 PM »
I know the advertised hp is 275 on a 340, but how much hp can I get out of a 340 with today'S modifications available?
I'm hesitating on buyin my first cuda because it's a 340 and I'd like to get at least 350hp without paying too much.
Offline 72hemi
  • MEMBER SINCE JANUARY 2006
Re: 340....how much hp can be "easily" reached with a 340.
« Reply #1 on: May 11, 2008 - 11:34:07 PM »
350 hp out of a 340 is not hard, even with original iron heads. The right cam, intake and carb selection with maybe some porting on the heads and good compression will easily clear 350 hp.
1996 Dodge Viper GTS Coupe
Offline HemiOrange70
« Reply #2 on: May 11, 2008 - 11:41:24 PM »
I agree, cam, headers, manifold and carb, 70-71 340's were 295 hp stock :burnout:They they aren't refferred to the little hemi for nothing :burnout:
« Reply #3 on: May 11, 2008 - 11:42:53 PM »
I got an m1 tunnel ram for it :bigsmile:
Offline 74 340 4speed
« Reply #4 on: May 12, 2008 - 12:10:41 AM »
With the right heads/cam/compression, you can get 450 HP easily on pump gas.
Andy
1967 Camaro SS: 406 sbc 505 hp/506 ft lbs|4 speed|Posi|3.73s
1969 C/10  350|Turbo 350
1969 Dodge D300 318|4 speed|Dana|4.88s
1972Nova: 350|Turbo 350
1974 'Cuda: 340|4 speed|Dana 60|4.10s|posi
1999 Camaro SS: Auto|Longtube Headers|True Duals|TT2s
2013 Challenger R/T: 6 speed|Hurst with pistol grip|mopar performance exhaust|super track pak
Offline moper
« Reply #5 on: May 12, 2008 - 11:53:45 AM »
1.1hp/cubic inch (375ish) is very easy using modern machining, and a modern cam grind, with all other parts  being factory (carb, intake, ignition, etc) including exh manifolding. 1.25hp/cu inch (425) will need better intake, more compression, better ignition and bigger carb, maybe gasket match the intake ports. Over that, you need to do soemthing with the heads in terms of proting or replacement. The biggest gains are from the beter machining (which blueprints the build and uses modern theory in terms of valve jobs) and the modern cam grind.
