Author Topic: 340 not pulling the way it should  (Read 6936 times)
Offline moper
Re: 340 not pulling the way it should
« Reply #75 on: May 19, 2008 - 11:47:26 AM »
You 2/3 problem is called flaring, and it can mean that the 2nd gear band is loose, or gone, or the 3rd gear clutch is gone/going, or the valve body isnt setup right (if it still has a "Drive" 3rd gear). If they adjusted it, it's not a good thing.
Offline leanburn
« Reply #76 on: May 19, 2008 - 02:40:07 PM »
that forces me to ask another stupid question  :1zhelp:.
if this is a manual body, should it go directly into second at an idle? the reason i ask is it goes into first until about 10mph.
nivvy
« Reply #77 on: May 19, 2008 - 03:45:16 PM »
In my manual valve body it stays in first till I bang 2nd and so on......... I think of a fairbanks automaitc I believe its called you put it in D and it goes through 1-2-D ... when just smashing the pedal.... its a little different from a regular auto..... The manual valve body will not shift until you shift it... hence "manual" valve body .......
Offline leanburn
« Reply #78 on: May 19, 2008 - 04:16:58 PM »
so with yours [stroker] if you shift to second at an idle will it go into second or do you have to get moving? the reason i ask is i don't know if i actually have a manual body, the guy said it did but i realy don't know and if i don't have a manual then this may explain my tranny issue.
is there any other way to tell without taking the tranny apart?
nivvy
« Reply #79 on: May 19, 2008 - 04:29:40 PM »
when i put my car in D yes it will pull out but its like pulling out in 3rd in a stick car........... boggish  :working:
nivvy
« Reply #80 on: May 19, 2008 - 04:40:16 PM »
also I have no kickdown linkage...............
