Author Topic: See if you think this will work  (Read 1796 times)
Offline Confederate Cuda
« on: May 12, 2008 - 07:38:32 PM »
I am going to order my wheels tomorrow but wanted to get all of your opions first. I am going with the Fikse Mach V wheels (see pic below) and after I did some measuring this is what the guys at Fikse recommend but I want to make sure they fit. I am running an alterkation frontend and 4 link muscle bar rear with stock wheel wells
Front 8 x 18   BS 5 3/8   FS  3 3/8  Tire Nitto 555 245/45/18
Rear 10 x 18   BS 5 3/8   FS 5 3/8   Tire Nitto 555 295/45/18
Anyone see any problems with that fitting?
Offline GoodysGotaCuda
Re: See if you think this will work
« Reply #1 on: May 12, 2008 - 07:43:46 PM »
Dont see why it wont, im running that rear tire with stock rear leaf spring location (though i have a 9" rim), and running a 255/45/17 up front so a little wider.
I am running 4 1/2" backspacing up front, i would think that maybe with that front end you could get something like the 275's some of the guys on this board are running with stock front ends?
1976 Dodge Warlock
Wheel & Tire Specs:Link
« Reply #2 on: May 12, 2008 - 10:02:20 PM »
Thanks Goody
I think that 245 or 255 is a wide as I would want to go up front. What did you use for backspace on the rear? I know these will likely work but it still makes me nervous because they cost a ton and if they don't fit you have very expensive door stops.
« Reply #3 on: May 13, 2008 - 05:08:08 AM »
I really don't see how 5 3/8" back-spacing will work without modifications.  :clueless:
« Reply #4 on: May 13, 2008 - 07:16:40 AM »
He has a four link, so no leaf spring interference. Only the wheel wells are stock, no tubs.
« Reply #5 on: May 13, 2008 - 07:26:07 AM »
rear bs is 5.9" - 7/16" wheel spacers. i also have 3" studs
1976 Dodge Warlock
« Reply #6 on: May 13, 2008 - 09:45:26 AM »
So Goody if my math is correct your true rear backspace is about 5 3/8 with a stock setup? 5.9 - 7/16 = ~5 3/8
« Reply #7 on: May 13, 2008 - 12:17:50 PM »
Sounds right, however running the 10" wide you may want a hair more bs since you dont have leaves to worry about. 5.5"?
1976 Dodge Warlock
« Reply #8 on: May 13, 2008 - 12:46:46 PM »
The more I think about it I will need to run more backspace as the frontspace will be too tight. I have 7.5" front the face of the rotor to the 4 link bar so 6 or 6.25 backspace should work correct?  My measurment for the front space was 5.75" from the front of the rotor face to the inside of the wheel well lip.
« Reply #9 on: May 13, 2008 - 03:18:41 PM »
The more questions I ask the more confused I seem to get :clueless: When I spoke to the guys on the phone from Fikse they told me that the Mach V could be 6 3/8 BS with 4 3/8 FS or the next size would be 5 7/8 BS and 4 7/8 FS. One thing that has me a little puzzled is that the back space and front space add together to equal 10 3/4. Is that normal for a 10" wheel  :dunno: I always thought the BS and FS would add together to equal 10. I can't believe how hard this seems to be  :banghead:
« Reply #10 on: May 13, 2008 - 05:16:46 PM »
Sorry can't help on the front spacing. I never even had those figures when i purchased my wheels, i went strickly off backspacing.
However, remember, you can always take away backspacing (spacers), you can't add it. So if you spend the $$ on too little backspacing, you own 'em. Which is why i went a little more and just spaced them off some. I'd think 6 3/8 may be a little deeper than you'd like, my 5.9 just barely started touching my leaf spring, spaced 7/16" i still have plenty of 1/4 panel clearance.
1976 Dodge Warlock
« Reply #11 on: May 13, 2008 - 06:23:49 PM »
So here is the latest. I spoke with the owner, Jim Fikse, and he was very helpful. He seems to think I can get a 10.5 inch wheel in there with 6 3/8 backspace. I am not so sure but what was even better is that he is going to fedex me a wheel so that I can test fit it this weekend. How is that for service  :bigsmile:  I have also been thinking more about the tire size and think that I will go with KDZ2 295/35/18 on the rear and 255/40/18 on the front. I like the look of Goodys dads car and mine has airbags as well. That will make a 26" tire front and rear. I will keep you posted
« Reply #12 on: May 13, 2008 - 09:33:46 PM »
Thats awesome he is sending you a wheel! As far as the short tire, i do like my meat/height, but to each their own!! 26" would kill me with 3.91s   :faint: Next time we have a pair of wheels off either car i think we're going to try my wheels on his challenger just for kicks
 :icon16:
Here is Dad's car, have you had a chance to put some miles on the air bags? Do you have air-ride?
it does look right when you drop it down
 :grinyes:
and my front tires are 26.1" tall if it helps at all with the visualization
« Last Edit: May 13, 2008 - 09:36:32 PM by GoodysGotaCuda »
1976 Dodge Warlock
