Author Topic: Is my battery toast?  (Read 1867 times)
Offline JayBee
« on: May 12, 2008 - 08:47:34 PM »
Well I went in the garage to show a friend that everything works after I put the dash together and as soon as hitting the top lift switch everything went dead. No interior lights, no headlights, no horn, not even the clock. BUT, everything worked fine yesterday and I disconnected the negative before coming in last night. Anyway after a few minutes (and him laughing) the clock did start working but stopped the second I tried anything else electrical. The battery was in the basement during winter and I will be taking it in for a test tomorrow but just thought I'd ask for some opinions. One other thing, if there's a wiring problem could it discharge with the negative disconnected? Thanks...John
John
1970 Barracuda convertible
2014 Toyota Avalon
Re: Is my battery toast?
« Reply #1 on: May 12, 2008 - 10:19:04 PM »
Could be a loose connection at the battery the fuse-able link may be mostly fried and plenty of issues occur at the bulkhead connector, doesn't take much battery to run the clock.
« Last Edit: May 13, 2008 - 09:22:06 AM by bullitt99 »
« Reply #2 on: May 13, 2008 - 12:40:43 AM »
sounds more like a bulkhead connector problem try some di-electric grease , start checking & cleaning all the connections , possibly a lose wire at the rear of the ammeter also
Offline Aussie Challenger
« Reply #3 on: May 13, 2008 - 06:01:38 AM »
  No, the battery needs both terminals connected to discharge, having said that over a long period the battery will break down internally if it is not kept charged up. Modern batteries are designed to be kept fully charged.
Offline 73Chally
« Reply #4 on: May 13, 2008 - 09:11:43 AM »
I had a similar problem a couple years ago.  As soon as I would start to turn the key, everything would go dead.  A little fiddling with the wires under the hood, and sometimes it would start working again.  Turned out to be a short in the negative battery cable itself.  Are your cables new or old?
Offline JayBee
« Reply #5 on: May 13, 2008 - 07:08:20 PM »
Well the battery checked out AOK. Thanks for all the ideas and responses. To make a long story short...it was bad battery terminal connections. Sorry, but I never would have thought that the connection could be so bad as to not even turn on the interior lights when the door opens. Go figure. I hope you all understand; first everything worked, then nothing, already worked a lot on the car, it was getting late and I was getting frustrated. Sound familiar. Anyway, everything works, I changed the oil, started it up and the itch came back. Weather permitting, the seats will go back in this week and maybe even the first cruise on the weekend. Thanks again guys.
John
2014 Toyota Avalon
« Reply #6 on: May 13, 2008 - 07:11:37 PM »
I knew it wasn't the battery. Even with an ounce of life, it would still power the clock. I'm glad you got it solved.  :thumbsup:
Offline Robb
« Reply #7 on: May 14, 2008 - 11:45:18 PM »
Ive had it where it would it would go "click-rrrrr"  and then every thing going dark....    a little jiggle of the cable on the batttery and varoooom.
It happens.
70 Challenger SE  (440 SIX PACK / Keisler 5 speed, R/T SE replication)       68 Sport Satellite Convertible 383 Super Commando / 727  Survivor
2002 Trans AM WS6 convertible:  DD
1999 4Runner 4x4:  lifted-locked-armored  expedition vehicle
1990 Jeep XJ 4x4:  Front Dana 60, GM-14bolt rear, 3 link, 4link, 5.38 detroits, beadlocked 40's, stretched to 110" wb  Rock Crawler
