Author Topic: MSD WIRING  (Read 2974 times)
Offline 71cudda
MSD WIRING
« on: May 12, 2008 - 10:05:50 PM »
CHRYCO, YOU HAD SAID IN MY PREVIOUS POST THAT THE BROWN & THE BLUE FROM THE HARNESS SHOULD BE TIED TO THE RED SWITCHED WIRE FROM THE MSD. THE WAY THE CAR WAS WIRED BEFORE HAD THE SMALL RED WIRE FROM MSD BOX SPLICED INTO LIKE A 8 OR 10 GAUGE WIRE RUNNING TO POS TERMINAL ON BATTERY  THE BLUE WIRE W/ PLASTIC CONNECTOR & THE DOUBLE BROWN W/ PLASTIC CONNECTOR SEEMED TO BE JUST UN-USED DOES THIS SEEM ****** UP
nivvy
Re: MSD WIRING
« Reply #1 on: May 12, 2008 - 10:15:46 PM »
In my challenger I have the red msd wire tied in with my blue wire coming from the harness....   :chatting:
Offline 71cudda
Re: MSD WIRING
« Reply #2 on: May 12, 2008 - 10:18:21 PM »
JUST THOSE TWO WIRES AND NOTHING ELSE RIGHT. BECAUSE THATS WHAT MY MSD DIAGRAM SHOWS
nivvy
Re: MSD WIRING
« Reply #3 on: May 12, 2008 - 10:22:51 PM »
All I have is the red msd wire tied into my blue wire from the factory wiring... yes those 2 wires...
Offline 71cudda
Re: MSD WIRING
« Reply #4 on: May 12, 2008 - 10:23:40 PM »
THANKS
nivvy
Re: MSD WIRING
« Reply #5 on: May 12, 2008 - 10:26:34 PM »
I am running a msd pro billet distrubtor with magnetic pick up...
Offline 71cudda
Re: MSD WIRING
« Reply #6 on: May 12, 2008 - 10:29:32 PM »
ME TOO
nivvy
Re: MSD WIRING
« Reply #7 on: May 12, 2008 - 10:30:43 PM »
I am postivive 100% sure I only have mine tapped into the blue wire...........  :working:
Offline 71cudda
Re: MSD WIRING
« Reply #8 on: May 12, 2008 - 10:35:44 PM »
YA MY MSD MANUAL SHOWS IT GOING OUT IGNITION [ORIGONAL COIL + WIRE, IMJUST NOT SURE ABOUT THE BROWN WIRE THAT CHRYCO SAID TO TIE INTO IT BECAUSE ON THE OLD HARNESS THERE WAS A BROWN TWO WIRE CONNECTOR BUT IT WASNT HOOKED UP TO ANYTHING
Re: MSD WIRING
« Reply #9 on: May 13, 2008 - 12:43:34 AM »
hooking it to the battery means it is always on & will kill the battery
the blue wire at the ballast is ign run & the brown is ign start , if you do not tap into both the car will either crank & not start or it will start until you release the starter  & quit
Offline 71cudda
Re: MSD WIRING
« Reply #10 on: May 13, 2008 - 12:50:08 AM »
just to make sure i am exactly clear,you are talking about the blue&white and the brown two wire should all be spliced together with the smaller red msd  wire and i can lose the wire that now goes to the battery
Re: MSD WIRING
« Reply #11 on: May 13, 2008 - 01:10:43 AM »
there is a Dk Blue wire at the ballast but the Lt Blue wire is 12 v power to the ECU & will work also
nivvy
Re: MSD WIRING
« Reply #12 on: May 13, 2008 - 05:27:15 AM »
okay I see what cp was telling you know.... I just straight wired mine into the light blue wire under the dash... :working:
« Last Edit: May 13, 2008 - 05:29:10 AM by StRoKer »
Offline shatar4
  • 71 Challenger
Re: MSD WIRING
« Reply #13 on: May 18, 2008 - 11:49:48 AM »
So if the blue/white and the 2 brown wires are hooked to the small red wire on the MSD box, does the large red wire still get hooked to the battery or is it no longer needed?
1971 Triple black 340 Challenger
Offline shatar4
  • 71 Challenger
Re: MSD WIRING
« Reply #14 on: May 18, 2008 - 05:29:34 PM »
bump
