Author Topic: Hood Pins  (Read 1094 times)
Offline t1971Chally
Hood Pins
« on: May 13, 2008 - 05:46:38 AM »
 :dunno: Ok, I need your help.  I am installing hood pins on my 71 challenger.  Since the front edge of the hood is angled outward to a point in the middle, I need to know how the hole patterns of the bezels ( plate installed to the hood) line up on the hood.  Are they to be turned so that they line of with the front edge of the hood?  Or,,,,Do you install them as if you snapped a line across the hood from left to right and line the hole patterns up with each other?  Hopefully this makes sense??? Thanks for your help!!!
Ted
1971 Dodge Challenger 440 Magnum
:cheers:
Re: Hood Pins
« Reply #1 on: May 13, 2008 - 08:19:23 AM »
I did it the first way. I believe that was the correct way from the factory, but I went that way because I thought it looked better.
Offline R/T
  • Johnson City TN
Re: Hood Pins
« Reply #2 on: May 14, 2008 - 07:52:34 PM »
Mike can you show a pic?
1973 Challenger (OO/=====\OO)  440
Hemis and Harleys
2008 Dodge Ram Big Horn Edition  5.7 Hemi
nivvy
Re: Hood Pins
« Reply #3 on: May 14, 2008 - 08:33:23 PM »
all i did was put the hood pins in on the car.... marked to top of the chrome hood pins with paint and closed the hood down and it lef a paint mark on each side of the hood where to drill into the hood so it lined up... hope that makes sense....  :working:
Offline t1971Chally
Re: Hood Pins
« Reply #4 on: May 14, 2008 - 08:43:50 PM »
Stroker, I have the pin holes drilled.  It is the chrome plates with the 4 mounting holes that I need help with.  What I do not know is how they are aligned?  In other words, are the holes aligned with the front edge (remember, the front edge of the hood is slightly v shaped) of the hood or are they aligned with the holes on the other chrome plate on the other corner (as if you stretched a string across the hood and lined the holes on each plate to the other plate?  make sense????  Thanks for your help? Twiles
Ted
:cheers:
Re: Hood Pins
« Reply #5 on: May 15, 2008 - 04:57:53 AM »
This is the best I have on my 'puter...
Offline R/T
  • Johnson City TN
Re: Hood Pins
« Reply #6 on: May 15, 2008 - 08:03:48 PM »
Thanks Mike, that is what I was looking for.
Hemis and Harleys
Offline Born_Fast
  • RIGHT PEDAL :: LEFT LANE
Re: Hood Pins
« Reply #7 on: May 28, 2008 - 08:38:01 AM »
Mike,
what's that little thing on your fender, underneath the tapeline between 3-4?
Looks like a watersprayer for the windshield. If so then it's damn far out in the front.
Re: Hood Pins
« Reply #8 on: May 28, 2008 - 11:43:09 AM »
Mike,
My car came with turn signal indicators on the front fenders. Instead of being chrome, they are painted body color.
