Author Topic: Speedometer gear question  (Read 2962 times)
Offline 72hemi
  • MEMBER SINCE JANUARY 2006
« on: May 13, 2008 - 03:58:54 PM »
Not sure if this belongs here or in the transmission section, so I apologize in advance to the mods if I misplaced. Anyways the speedometer in my cuda is off and I want to fix it. I have 3.55 gears and 235 60R 15 tires on the back (approx. 26.1 inches tall) and was wondering what gear I need. I currently have a 32 tooth gear and know that I need one with more teeth, from a couple of charts that I have read it looks like I need a 36 tooth gear. Can anyone verify that before I start ordering speedometer pinion gears.
1996 Dodge Viper GTS Coupe
Offline GoodysGotaCuda
Re: Speedometer gear question
« Reply #1 on: May 13, 2008 - 04:55:53 PM »
Looks like 36 tooth to me as well.
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline Changin Gears
« Reply #2 on: May 13, 2008 - 05:12:40 PM »
All you have to do calculate the number of teeth required is measure how far off your current speedo is, convert to percent, then get a new gear with the same percentage different teeth.  Example:
Hold your speed at 60mph between 2 mile markers, it requires 54 seconds to travel the distance instead of 60 (you could also use a GPS to get your true speed).  Your speedo is reading 10% low (your really going 66mph).  In this case, if your current gear had 30 teeth you would need one with 27 teeth (10% less) to speed the speedo up.
I have also used this equation:
Number of Teeth = 259 * (axle ratio/tire diameter)
« Last Edit: May 13, 2008 - 05:20:07 PM by Changin Gears »
Offline 72hemi
« Reply #3 on: May 13, 2008 - 05:21:20 PM »
Thanks for the formula. From my calculations I need a 35.25 tooth gear, so is it better to agree with the charts and get the 36 tooth gear, or should I round down from my results and get the 35 tooth gear?
« Reply #4 on: May 13, 2008 - 05:27:53 PM »
If you calculate your true percentage off and chose your gear that way, you are "calibrating" your speedometer.  This is better than a calibration that was done 30+ years ago.
Offline 72hemi
« Reply #5 on: May 13, 2008 - 05:42:08 PM »
Perfect, thanks.
Offline 422STROKER
  • Member Since 6/3/06
« Reply #6 on: May 17, 2008 - 04:36:05 PM »
Where did you get the gears?  I need a 32 according to that formula.  Right now I'm reading too high with the current set-up.
Tom :drunk:
Tom
Offline RDF
  • The pain that greets me is the stick that beats me
« Reply #7 on: May 17, 2008 - 07:58:38 PM »
This thread is right up my alley.....I need a new gear too, seeing as how my speedo says I'm doing 70 when it's actually about 50.....I've got 3.91's
Bob
1973 'Cuda
If we never drown we'll never know how well it tastes....So tell me how it tastes and I'll know just how well you drowned.
My build:
http://www.cuda-challenger.com/cc/index.php?topic=45749.0
« Reply #8 on: May 18, 2008 - 04:24:39 AM »
Tom :drunk:
Tom,
  I got mine from Year One. I got a 33 tooth laying around here someplace, but the rest of what I got are 30 or less.   :pullinghair:
Offline 422STROKER
« Reply #9 on: May 18, 2008 - 08:02:28 AM »
Thanks Mike, I think I got a pretty sweet deal on one from 72Hemi!
Thanks Again!
Tom :2thumbs:
Tom
« Reply #10 on: May 18, 2008 - 08:47:06 AM »
The dealer may still have them, although they would be superseded to newer part numbers.  The original part numbers were 2538926 through 2538945 with the last 2 digits being the number of teeth.
