Author Topic: Which Throttle Cable  (Read 737 times)
Offline 440FIED
« on: May 14, 2008 - 01:16:47 PM »
I just put a 499ci in my 72 challenger, I am using the indy 440-1 heads and their 4150 style single plane manifold with the 4500 series dominator adapter and the tall throttle bracket from indy,my stock 340 throttle cable is too short. Does anyone with the same setup know what throttle cables will work?
Offline 422STROKER
  • Member Since 6/3/06
Re: Which Throttle Cable
« Reply #1 on: May 14, 2008 - 01:29:09 PM »
I think the /6 cable is the longest.
Tom :2thumbs:
Tom
nivvy
« Reply #2 on: May 14, 2008 - 04:08:14 PM »
put in  a lokar cable setup.........  :2cents:  I did........... I have 4150-4500 adapter.... I am as tall as you can get with the hood still closing.......... cut to fit length...... Like my suicide shifter.......  :bigsmile:
Lokar Cable
http://store.summitracing.com/partdetail.asp?autofilter=1&part=LOK%2DTC%2D1000HT&N=700+115&autoview=sku
« Last Edit: May 14, 2008 - 04:12:43 PM by StRoKer »
