Author Topic: Dim headlights at idle....simple fix?  (Read 7533 times)
Offline Justins72
Re: Dim headlights at idle....simple fix?
« Reply #15 on: May 28, 2008 - 11:12:43 AM »
would you need 4 relays since for a challenger since it has 4 lights or just 2 (one for low and one for high)?
Offline GoodysGotaCuda
« Reply #16 on: May 28, 2008 - 11:34:19 AM »
no still just two relays. 2-headlight cars have three wire bulbs, high, low, ground. 4-headlight cars have low-ground & high-ground.
1976 Dodge Warlock
Wheel & Tire Specs:Link
« Reply #17 on: May 28, 2008 - 11:09:51 PM »
 to state it clearer 1 relay for low beams circuit
1 relay for high beams circuit no matter if you have 2 or 4 lights on the circuit the draw from 4 lights is still far less than the 30 amp rating of the  relay
Offline easy610
  • Keeping Michigan zombie free one round at a time..
« Reply #18 on: May 28, 2008 - 11:51:36 PM »
While not the cheap route, I just bought and installed the Painless Wiring headlight relay package and drove it just now at night.  WHAT a difference.  Thanks to all for the info!
One issue/concern checked off the list!
I can see, I can see!!!
1972 'Cuda 340 4spd, Blk/Blk.
Sold November 2012.  Will be missed and fondly remembered...
Replaced by this..I know, I know it ain't no classic...but it doesn't rattle and is wicked fast even with AC on...
« Reply #19 on: May 29, 2008 - 12:59:03 AM »
Very glad to hear it worked out for you! did you do any voltage checks before and after?
1976 Dodge Warlock
Offline easy610
« Reply #20 on: May 29, 2008 - 08:33:42 AM »
Naw, I forgot to....
I work afternoons and got off early (11PM) and got home...wife and kids asleep so I decided a good time to start drinking and working on the 'Cuda!
Next thing I know its 3AM and I'm sitting in my driveway in the 'Cuda idling with BRIGHT headlights!
Nothing like 5 hrs of sleep!
