Author Topic: 70 Challenger Bumper Jack Mast Length  (Read 1386 times)
Offline David Disckind
« on: May 15, 2008 - 09:56:32 AM »
I am restoring a 70 Challenger 440-6 R/T SE, and recently purchased a bumper jack on E-bay.  I am trying to confirm the correct mast length for the tube style mast, as opposed to the solid wye type which I understand should be 34-1/2".  The rivet has and 0D, so it is correct for a 1970 vehicle.
Thanks,
David
Offline 70challrtse
Re: 70 Challenger Bumper Jack Mast Length
« Reply #1 on: May 15, 2008 - 03:26:16 PM »
David, did Rick not answer your question? If not call Franl Badalson, never mind I will call Frank I need to talk to him any way. And by the way I took the mast ( solid type) out and it is actually closer to 34.25. Ron in Plano
« Reply #2 on: May 15, 2008 - 04:09:26 PM »
I have e-mailed Rick who indicated he could restore it, but was not sure of the mast length.  He indicated he would check but I have not heard back yet.
Thanks,
David
Offline 70challrtse
« Reply #3 on: May 15, 2008 - 04:26:03 PM »
I just got of the phone with Frank Badalson, who I consider to be an authority on most Mopar matters, and Frank indicated that for the tube type mast the length could be 34" or 35.25" . Both have the same patent #.
« Reply #4 on: May 15, 2008 - 05:29:11 PM »
My mast is about 35-1/8" with patent number 3163925 stamped into it.  Did he note the patent number?  It's sounding like I'm good with the jack I purchased.
I appreciate your help Ron!
Offline 70challrtse
« Reply #5 on: May 15, 2008 - 09:39:26 PM »
No, I'm sorry I don't. Frank is easy to get hold of, let me know if you need his #. Frank's like me, it's easier to reach him by phone.
« Reply #6 on: May 19, 2008 - 04:21:32 PM »
Heard back from RestoRick and also talked to Frank today.  They both verified the tubular mast length was 35-1/8".  Frank also confirmed the Patent No. listed above and that the tubular mast was likely provided in a Nov. 69 build date car like mine.
Yahoo!!
Just thought I'd share what I learned today.
Thanks,
David
Offline 70challrtse
« Reply #7 on: May 20, 2008 - 11:07:11 AM »
That's good to hear David; I knew Rick or Frank could answer your question.
