Author Topic: Reading a spark plug  (Read 1103 times)
Offline wally426ci
    • maryland mopars
« on: May 15, 2008 - 11:15:40 AM »
So, i just changed my AutoLite Platinum plugs to Champion RN12YC (recommended from a buddy)
I noticed that the electrode was worn in the middle (almost in a cone shape)
the insulator was a frosty white with a little tanning, and the color change on the ground strap was a little closer to the threads than in the middle.
this article notes that that can be caused by too much timing http://www.4secondsflat.com/Spark_plug_reading.html
but does that mean i have too much advance? or too much initial....?
 :chatting:
« Last Edit: May 15, 2008 - 11:22:55 AM by wally426ci »
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Offline GoodysGotaCuda
Re: Reading a spark plug
« Reply #1 on: May 15, 2008 - 12:03:51 PM »
looks a little leak and the timing is too far advanced. best reading for mixture would be a brand new plug at full throttle with minimum idling. i believe that is too much advanced, ill have to look at my stuff and see for sure.
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline moper
« Reply #2 on: May 15, 2008 - 01:22:58 PM »
First, I'd say yo are very close, the timing might be a little off, but I look for flecks or black spheres on the ceramic with a magnifying glass if I'm worried about it. Second, that's a platinum plug.. They come that way (center electrode I mean...) It's not worn. They put a sharp corner on them so the spark jumps easier.
Offline wally426ci
    • maryland mopars
« Reply #3 on: May 15, 2008 - 01:48:26 PM »
Very interesting.........  :clueless:
Thanks!
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Offline DanGoodman
  • MOPAR OR NO CAR
« Reply #4 on: May 15, 2008 - 02:59:26 PM »
You really should use NGK plugs.........they work best on High performance engines - 02
 :stirpot:
MOPAR FAMILY
nivvy
« Reply #5 on: May 15, 2008 - 03:43:45 PM »
If the discoloration is to close to the top you are running 2 cold of a plug... too far down the strap closer to bottom and you are too hot... you wanna find a plug right around the middleish about 4-5 threads down.... depending if its an extended reach plug or not...
« Reply #6 on: May 15, 2008 - 06:46:49 PM »
Wally,
 I would throw that sucker back in and not worry so much. You have to be close, if not just about "on" with timing and carb jets size.
Offline wally426ci
    • maryland mopars
« Reply #7 on: May 15, 2008 - 08:34:47 PM »
Really? i was convinced that i need to downsize my metering rods and jets, its a little rich in the highway cruise. I have always thought ive had a little bit of a miss.....
Oh well, i already changed to the champion plugs, so if they suck i'll run NGK  :dunno:
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
« Reply #8 on: May 15, 2008 - 08:36:11 PM »
Wally you'd need to upsize metering rods if you are running rich. Thicker the rod, less fuel = leaner. However that plug doesn't look rich to me..
1976 Dodge Warlock
« Reply #9 on: May 16, 2008 - 01:43:50 AM »
the pic at the top of this thread looks way lean to me , you will pick up milage & power if the plugs are in the tan brown range
Offline wally426ci
    • maryland mopars
« Reply #10 on: May 16, 2008 - 10:30:57 AM »
So, i need to Richen this puppy up..... Im going to work on fine tuning it in the next couple weeks. I havent worked on it much, not to mention having not driven it further than a few miles this year...... been busy...
 :working:
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
