Author Topic: Why is Dexron III recommended for the 727 over factory recommendation?  (Read 6055 times)
Offline NorthWestcuda
I'm trying to figure out why Dextron III is recommended "within this website" for the 727 autotrans over the factory recommendation?  What are the pro's and con's?
Thanks Guys,
1973 Cuda, 440 engine
1972 Chevy 4x4 PU stepside
2003 Ford F-350 Diesel
Offline GoodysGotaCuda
What is the 'factory recommendation'?
I run Type F  :stirpot: :bigsmile:
1976 Dodge Warlock
Wheel & Tire Specs:Link
Lets see if "Tactransman" can answer this?  I'm flushing the trans now and somewhere in this site there was a post that said to use Dextron III.   I thought\assumed chysler\dodge transmissions wanted a different type of transmission fuild, but for the life of me I don't know what type???  DAAAAA............... :clueless:
I know the newer stuff is ATF+4 for chrysler. I've always heard Dexron III is the refill, Type F if you want a little firmer shift. However that is on the fence for shift firmness..
1976 Dodge Warlock
Offline arcticmopar
  • Yukon Canada
I believe 727'/904's used Dextron from new, replaced by DexII now DextronIII. The type "F" can be used to provide a firmer shift or less slip? :clueless:
« Last Edit: May 17, 2008 - 04:56:25 PM by arcticmopar »
RUNS WHITH SISSORS!  and  DIGITALY CHALLENGED!
Offline 422STROKER
  • Member Since 6/3/06
Can Type F be mixed with Dextron?
Tom
Just wondering as I'd like to firm up my 904 until the 727 is ready.LOL  I don't think I could get all the Dex out.
Tom
It'd mix okay, do you have a shift kit of any kind? Just a heads up on i wouldn't expect any dramatic changes from the fluid change, minimal.
1976 Dodge Warlock
Offline TommySS
  • Forgot more than most will know...
Type F was for Ford.  Dexron was (typically) for GM.  I believe I ran Dexron in my R/T.  Don't know if I'd want to mix 'em though.
Offline 422STROKER
I followed an article from Mopar Action a while back I think it showed a similar mod to the trans-go job.  Plus I had an old guage from a B+M kit to adjust the pressure.  Pretty good, just looking to get a little more life out of this old beat up 904.  The Stroker is putting some strain on her. :bigsmile:
I might give it a go.
Tom :crazy:
Plus I think my trans(727) will be done soon anyways, although I need a new shaft for it too.
Tom
I believe type II has been discoed & replaced with type 3 & 4
I have always heard to use ONLY type F or dextron & to initially fill the trans with type F after a rebuild if you want to use it , it is supposed to cause the clutches & bands to bite I bit harder
Offline tactransman
Dexron III is the easiest to get,cheapest to get and is very adequate for a 727/904. ATF+4 is fully synthetic and is  :money:  Type F is harder to get and I have seen no difference in shift quality with it. :cheers:
Terry-tactransman
Union, Mo.
