Author Topic: tach help  (Read 1908 times)
sleepychallenger
tach help
« on: May 19, 2008 - 07:00:06 PM »
i installed the MP electronic ignition, what do i need to do to get the tach to work ??? i read the instructions once but my buddy threw them away when i was out. it said something about the wire that goes to the distributer should be hooked to the neg on the coil?  :feedback:  :working:
Offline GoodysGotaCuda
Re: tach help
« Reply #1 on: May 19, 2008 - 07:01:02 PM »
factory tach? or aftermarket?
not positive on the factory tach, but in general they will pickup off the negative coil terminal
1976 Dodge Warlock
Wheel & Tire Specs:Link
sleepychallenger
Re: tach help
« Reply #2 on: May 19, 2008 - 07:03:21 PM »
factory tach. but i wasnt sure if i had to cut a wire and reroute or if i need to splice or what.
Re: tach help
« Reply #3 on: May 19, 2008 - 07:16:46 PM »
The original tach gets it signal from the "-" side of the coil, but if your's hasn't been rebuilt, I'll bet it is toast. They only last a little longer than the original clocks did.   :stomp:
sleepychallenger
Re: tach help
« Reply #4 on: May 19, 2008 - 09:01:33 PM »
it worked up until i had a fire under the hood. i just thought that maybe the wiring got toasted and never got hooked back up right, how would i check it? that is the gauge that i hate seeing dead the most
Re: tach help
« Reply #5 on: May 20, 2008 - 12:00:29 AM »
as long as you connect the wire to - coil & have power to the guage it should work , how accurate it may be is another story
sleepychallenger
Re: tach help
« Reply #6 on: May 20, 2008 - 12:21:25 AM »
which wire   :clueless:
Re: tach help
« Reply #7 on: May 20, 2008 - 12:48:31 AM »
which wire what ?
the factory wire was usually grey with black trace on it , I can`t remember which terminal it comes through on the bulkhead connector
sleepychallenger
Re: tach help
« Reply #8 on: May 20, 2008 - 11:45:00 AM »
i just installed a MP electronic ignition and took out my points system. just wondering what wire i would need to move?
Re: tach help
« Reply #9 on: May 20, 2008 - 12:01:53 PM »
with points the connections to the coil are virtually the same , you had a black wire from the dist to the coil - terminal this is replaced by a black wire with yellow trace to the - coil ,there would be a second grey wire to the negative coil for the tach that needs to be reconnected to - coil for the tach to work
sleepychallenger
Re: tach help
« Reply #10 on: May 20, 2008 - 12:42:30 PM »
thanks. it is hooked up but not working. i imagine that my tach is dead. will have to get it rebuilt one of these days.  :violin:
Offline wally426ci
    • maryland mopars
Re: tach help
« Reply #11 on: May 20, 2008 - 02:25:03 PM »
my tach is way off, maybe you and I need a rebuild kit..  :dunno:
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
sleepychallenger
Re: tach help
« Reply #12 on: May 20, 2008 - 03:23:23 PM »
mine was wierd when it worked. it was way off, but then when i stompped the gas, it was accurate.
Re: tach help
« Reply #13 on: May 20, 2008 - 06:47:52 PM »
Guys,
  The original tach has a heavy needle, so it doesn't repond as quickly as the after-market tachs do. Once you get it rebuilt and calibrated, you will enjoy it. I watch that more than my speedometer. I had mine done here...  http://www.performancecargraphics.com/
sleepychallenger
Re: tach help
« Reply #14 on: May 20, 2008 - 08:01:23 PM »
Thanks Mike, maybe when i get back from the desert i will have it done.
