Author Topic: fuel pump outlet adapter size?  (Read 1128 times)
Offline Cudaah
« on: May 19, 2008 - 07:37:57 PM »
Does anyone know what the thread sizes are for the fuel outlet for the stock fuel pump?  I bought a 1/4" to 6AN aluminum adapter from summit and it barely turns a quarter turn.  Not sure if this might be metric or not.  Just don't wanna strip anything out.
Thanks
Re: fuel pump outlet adapter size?
« Reply #1 on: May 19, 2008 - 07:50:51 PM »
Depends, I got this info from NAPA webstore
340 pump Fitting Size(s):5/16"; 1/2"-20 UNF-2B
440 pump Fitting Size(s):5/16"; 5/16"
kudakidd
« Reply #2 on: May 20, 2008 - 12:25:11 PM »
it's a 1/4 NPT. make sure your is a pipe thread
Offline ntstlgl1970
  • T a c o c a t
« Reply #3 on: May 20, 2008 - 02:25:25 PM »
look in the outlet hole, is there a tube seat in there or an empty hole? tube seat= straight thread/steel tube fitting (think brake lines) and empty hole is usually pipe thread.
