Looking at the front of the carb Wally there are three vacuum ports. Big fat one in the middle, one on the left of that, one on the right. The
lowest port will be full manifold vacuum. That should be
plugged. The
highest port will be 'ported' vacuum and that
should be used, routed to your distributor. Of the top of my head Wally the ported should be the passenger side, full manifold should be the drivers side. So use the passenger side.
The only difference between the two is that one does not show a vacuum signal at low rpm (ported) and the other does (full manifold vacuum). You use ported so that your ignition isn't trying to advance too far sitting at idle.
Hope that makes sense
