Author Topic: Starting Issue  (Read 788 times)
Offline RusTy/SE
  • Just havin' fun
Starting Issue
« on: May 20, 2008 - 07:34:55 PM »
  My 86 D250 truck running a stock 87 360 is messing with me again :clueless:  In December a new battery was installed. Last April i jumped through hoops trying to pin down what turned out to be a failing coil after replacing the computer (used), distributor cap (new), rotor button (new) and fuel filter (new).
  Last friday the starter went out and i replaced it. Now she starts fine but every third or fourth startup ignition drags to the point where it barely turns over. No clicking - just arrrrruuuh, arrruuuh, arrrru :-[  In between she cranks as soon as I turn the key. I took it to AZ to check the battery and alternator. The battery tested good and the alt was registering 13.82 volts. Any ideas??
 :1zhelp:
« Last Edit: May 21, 2008 - 09:02:54 AM by onefornow »
Russ
2001 Durango     1B4HS
1970 Challenger  JS29U
Offline GoodysGotaCuda
Re: Cranking Issue
« Reply #1 on: May 20, 2008 - 07:39:27 PM »
how are your cables? good and tight? any 'funky' cable ends anywhere on there.
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline RusTy/SE
  • Just havin' fun
Re: Cranking Issue
« Reply #2 on: May 20, 2008 - 07:50:20 PM »
Negative cable is good and tight, positive cable is an nos item that i've had on hand for a couple of years and was installed when the motor was rebuilt. I made sure all its connections were good and tight after replacing the starter.
Russ
2001 Durango     1B4HS
Offline Oldschool
  • Member Since 9-05-06
Re: Cranking Issue
« Reply #3 on: May 20, 2008 - 08:27:32 PM »
Was the starter reman, rebuilt, or new?  Sounds like a bad starter, even though you just replaced it.  It happens more than you would think....    :2cents:
Ken  --  In Georgia
sleepychallenger
Re: Cranking Issue
« Reply #4 on: May 20, 2008 - 08:31:25 PM »
check your grounds
Offline RusTy/SE
  • Just havin' fun
Re: Starting Issue
« Reply #5 on: June 20, 2008 - 05:03:04 PM »
Bingo Ken :jumping: Today i replaced the starter with a reman hi-torque mini unit. Problem solved :cooldancing:
fyi: the positive cable coming from the battery terminates in both a small and medium connector; spend 30 seconds with a needle file wallering :icon16: it out a bit in order for it to slip onto the matching starter post  :thumbsup:
Gratuitous pic of the position necessary in order to tighten the top starter bolt. Even though the negative cable was off the battery, i made sure to ummm....not make contact with the positive post; i've heard tales of possessed Mopars :sly:  :poopoke: :roflsmiley:
Thanks everyone :wave: :working: :bigsmile:
« Last Edit: June 20, 2008 - 05:13:37 PM by onefornow »
Russ
2001 Durango     1B4HS
